G35 turbo build (VQ35DE)
Old May 20, 2016 | 09:06 AM
cugliari69@gmai's Avatar
cugliari69@gmai
Default G35 turbo build (VQ35DE)
Im getting an 04 g35 next month and I'm planning on boosting it but this would be my first turbo build and I don't wanna mess anything up. I wonder what kind of turbo I should get, how much boost I should run on stock internals, and if I should go twin or single.
Old May 20, 2016 | 09:17 AM
turboed350z's Avatar
turboed350z
4 82mm turbo at 50 psi will be enough.
Old May 20, 2016 | 09:20 AM
cugliari69@gmai
Lol I know a lot about cars and 50psi will blow the heads right off
Old May 20, 2016 | 09:31 AM
turboed350z
"Knows alot about cars." Cant post a serious question about the build he wants.... k den.
Old May 20, 2016 | 09:33 AM
cugliari69@gmai
So you're pushing 50psi on you're z
Old May 20, 2016 | 09:48 AM
turboed350z
I could if i wanted too. Psi is irrelevant at this point of the conversation
Old May 20, 2016 | 09:51 AM
cugliari69@gmai
What's done to you're motor
Old May 20, 2016 | 09:52 AM
turboed350z
Things.
Old May 20, 2016 | 09:57 AM
cugliari69@gmai
Things.
Alls I wanna know is can I boost 10psi on stock internals
Old May 20, 2016 | 09:59 AM
turboed350z
That depends.
Old May 20, 2016 | 10:03 AM
cugliari69@gmai
That depends.
On what though like that's what I'm trying to figure out
corbin9's Avatar
corbin9
His point is you are talking about doing a significant modification to your car and you have no base knowledge or at least come across as having none. Think about your goals, look at other peoples set-ups that are making similar numbers that you want and go from there.
What kit do you want to run? Are you building a kit yourself? Are you staying stock block? Are you racing the car or is it a street car? If you are racing are you doing HPDE, drift, ect? "What turbo should I run" is one of the last questions you should be asking.
Old May 20, 2016 | 10:04 AM
cugliari69@gmai
That depends.
And if I should go twin or single like what ones better proformace wise
turboed350z
Thank you! You want a serious answer, you gotta ask a serious question.
Old May 20, 2016 | 10:08 AM
cugliari69@gmai
I want to get 400 horsepower on a street car for now with a stock block and stock internals and I want to make the kit myself
Old May 20, 2016 | 10:16 AM
turboed350z
First, read the FI section. Next, do your homework and come back with a semi intellectual question. THEN we can continue.
400whp, with a custom ser up. Is your budget 50k or 5k? Difference between a single built and a twin build....
Ask a serious question, youll get a serious answer.
Ask a vague question, you get vague answer.
Old May 20, 2016 | 10:24 AM
cugliari69@gmai
My budget is 10K Max and I'll be sure to research all of this tonight after work
Old May 20, 2016 | 01:24 PM
corbin9's Avatar
corbin9
You can buy a nice pre-made kit with a tuning solution for your budget.
Old May 20, 2016 | 02:08 PM
cugliari69@gmai
If it's not out of you're way would you be able to send some links
Old May 20, 2016 | 02:59 PM
sportbiketed's Avatar
sportbiketed
https://www.google.com/
There you go buddy. You should be able to find all the kits with that link.
