350z limp mode help!!
Old Sep 23, 2016 | 05:42 PM
350zaddict's Avatar
350zaddict
Default 350z limp mode help!!
Guys so my dad took my 350z to his job and I told him it was low on gas so he said I'll fill it up for u. I end up taking the diseal to school and and when I get to work he took his truck and I took my car. I left the car there and soon my co worker said go get food so I head out and start the z. Soon as I leave in 1st gear it felt weird then when I started going it would start to redline athe 2500 rpm! I turned around called my dad and said tell me the truth did u put 93 in or not and he said cause of the gas situation here in NC that there was no 93 which was a lie. So I get my boss to go out and he tells me it's in limp mode and as soon as he hooks up his obd there was NO codes. He erased it and the car revved fine and was back to normal. He soon asked me if my dad put 87 and I said yeah and he said that was the problem cause u could smell the fumes from the car before. I ended up putting 3 octane boosters on it and let it sit for 3 hours. I get off work and the car hesitates real bad I'm 1st and my boss said it's normal just drive under 3000 rpm and when home it will cycle overnight and be back to normal. Please will someone tell me it will be fine?? Cause my dad drove it with some 93 still in it that's why he didn't have any issues but I did?? There was no code so was it the gas??
Old Sep 23, 2016 | 06:16 PM
jhc's Avatar
jhc
General & Tech Moderator
Well, it's not going to "Redline" at 2500 rpm, and 87RON will not cause "limp mode", just less acceleration.
if you smelled fuel, make sure your fuel cap is on. You did not say whether from front or rear.
When something goes wrong try to understand everything that changed. It is possible to get bad gas. If the station isn't very busy/underground tanks damaged or absorbing moisture...You might want to try a product like HEAT to eliminate any possible water in the system. Or siphon, or let it idle until empty. Then put 2 gallons of good 93.
The other possibility is something completely different has changed. Let us know what the problem was when you get it sorted. gl!
Old Sep 23, 2016 | 06:26 PM
dboyzalter's Avatar
dboyzalter
6 inch cawk is my fave!
Did he put 87 or diesel fuel in their? No reason it should smell like gas, or go into limp mode.
If theirs no codes to read what was erased?
Old Sep 23, 2016 | 06:44 PM
350zaddict's Avatar
350zaddict
He pressed erase on the obd and it revved back to normal but it was 87 gas
Old Sep 23, 2016 | 06:57 PM
travlee's Avatar
travlee
Master
too many beers to read your run-on paragraph . hard to tell what is going on, car wont redline at 2500, you can't clear codes that aren't there, i would fill it with whatever the highest octane you have and drive it
Old Sep 23, 2016 | 07:01 PM
dboyzalter's Avatar
dboyzalter
Your probably all set..
It got the octane booster, should be fine. I would just take it easy till that gets burned off (try to keep it under 4k)
Old Sep 23, 2016 | 07:18 PM
350zaddict's Avatar
350zaddict
Alright thank u but sorry other guys I've just been so preoccupied with the car I was typing to fast
Amy D'Anastasi
Sep 21, 2016 09:31 AM
Ant350
Jul 17, 2004 11:29 AM
J Ritt
Nov 11, 2002 05:22 AM
