P0300 after fitting decats
Old Oct 5, 2016 | 08:59 AM
David350zvq's Avatar
David350zvq
Default P0300 after fitting decats
Hi all I have a 2003 Nissan 350z with about 116500 miles I installed invidia de-cat stillen y pipe and agency power back box just a week after installing I have p0300 fault code.
I was driving down the road fine and all of a sudden it just sounds like not all the cylinders are working but it come and goes on cold start it's fine for about 30 seconds then it goes again and sounds like a Subaru boxer engine.
Could someone please tell me if I have caused this by installing the decats without a remap or is it something else
Thanks in advance
Old Oct 5, 2016 | 09:46 AM
travlee's Avatar
travlee
Master
test pipes... they are called test pipes!!!
http://lmgtfy.com/?q=p0300+nissan+350z
Old Oct 5, 2016 | 10:00 AM
David350zvq
What is your problem
Old Oct 5, 2016 | 10:07 AM
iideadeyeii's Avatar
iideadeyeii
Sounds like a boxer engine? Sounds like an upgrade to me.
Old Oct 5, 2016 | 10:15 AM
David350zvq
I wish it was an upgrade but it's very sluggish and I comes and goes and is so annoying
Old Oct 5, 2016 | 10:34 AM
Syner's Avatar
Syner
You're probably running too lean. Get it tuned sooner rather than later.
Old Oct 5, 2016 | 10:55 AM
travlee's Avatar
travlee
Master
change spark plugs and coil packs, you like syner said you are also lean from removing the cats
zacav8r
Nov 5, 2016 01:43 PM
phelannz
Sep 16, 2016 04:08 PM
Steve Mack
Sep 13, 2016 09:56 AM
bthezman
Suspension
Sep 6, 2016 11:42 AM
