Crank Pulley Question!
Old Jan 6, 2017 | 04:02 PM
louisville13's Avatar
louisville13
Default Crank Pulley Question!
Ive been having a hell of a time trying to break the bolt loose on the crank pulley and just want to make sure its not reverse threaded before i try a bigger impact wrench?
Old Jan 8, 2017 | 07:18 AM
eZg's Avatar
eZg
Do some searching...... There are a couple thread in which guys put a breaker bar on and use the starter to break it loose. Honestly ...I don't rem if it's reversed threaded or not.
Good luck man
Old Jan 8, 2017 | 10:47 AM
louisville13
Good luck man
ive read just about every thread i can find on it but no one mentions if its reverse threaded but a lot of guys i work with told me crank pulleys are reverse threaded alot. And seems the started method is the easiest way to remove the bolt but unfortunately for me the engine isnt in the car. Thank you though
Old Jan 8, 2017 | 12:19 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
not reverse threaded. Just need some umph.
I put a breaker bar and floor jack handle on it. Its gonna flex some.
the starter trick works too.
Old Jan 8, 2017 | 02:07 PM
louisville13
thank you!
Old Jan 8, 2017 | 02:08 PM
louisville13
how did you lock up the engine?
Old Jan 8, 2017 | 10:34 PM
bealljk's Avatar
bealljk
when I did mine it was my ~20" breaker bar with a 30" piece of pipe on the end...
Old Jan 9, 2017 | 06:19 AM
eZg's Avatar
eZg
prob the most ignorant sugg ever but when taking pulley off. in car....a common method is the zip tie pulley to structural member of car.
Not sure if you can do something similar with it out of the car???
good luck
Old Jan 9, 2017 | 02:15 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
put it in gear, like 6th, and e-brake.
Old Jan 9, 2017 | 02:32 PM
eZg's Avatar
eZg
Think it's on a stand. Like engine is out of car
Old Jan 9, 2017 | 02:52 PM
louisville13
The engine is on a stand. But i finally got the bolt out using a torch and a 850 ft-lb torque wrench. What a pain in the ***. But i did manage to do this to the pulley earlier when i tried a breaker bar. Does anyone think itll cause any problems?
Old Jan 9, 2017 | 03:20 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
depends if it bent into the belt path or not. I'd file it down and see.
If not, stock crank pulleys can be had for cheap. I should have one I could sell ya.
Old Jan 9, 2017 | 04:16 PM
louisville13
pm me and let me know a price shipped to 40059 please
Old Jan 11, 2017 | 05:11 AM
92K1500's Avatar
92K1500
I have a full set of lightweight pulleys still in the box that I will probably never install...
Old Jan 11, 2017 | 06:22 AM
louisville13
pm me with the brand and price please
Old Jan 15, 2017 | 06:54 AM
Cux350z's Avatar
Cux350z
hatersgonnahate
you do not want a lightweight pulley on the crank..will lead to future problems.
