Ignition Coil - Are screws grounded?
Old Jan 30, 2017 | 02:20 AM
Bilazaurus's Avatar
Bilazaurus
Default Ignition Coil - Are screws grounded?
Hi,
I have noticed that head of my bolt securing the ignition coil is broken, gone, snapped. Coil is a bit loose now, sitting still thanks to rubber boot in ignition coil. Now, of course I'll have the broken bolt removed and reinstalled but I was wondering if screw is providing a proper grounding for ignition coil. There's metal on coil's collar and mounting bolt looks more conductive than a usual one. Do you know if this screw and collar helps to ground the coil and provide better spark?
Old Jan 30, 2017 | 03:09 AM
92K1500's Avatar
92K1500
Isn't the valve cover plastic? That would insulate the mounts from any form of grounding.
Old Jan 30, 2017 | 03:11 AM
Bilazaurus's Avatar
Bilazaurus
It's not mounted to plastic cover. It's mounted to block I think.
Old Jan 30, 2017 | 03:31 AM
karlt's Avatar
karlt
The coils are bolted to the rocker cover (see the em.pdf section of the Service Manual, page EM-35). Coil ground is through the wiring harness (see the ec.pdf section, page EC-691). Page references are for my 2005 model.
Old Jan 30, 2017 | 04:03 AM
Bilazaurus's Avatar
Bilazaurus
Ok. Thank you.
Old Jan 30, 2017 | 04:04 AM
Bilazaurus's Avatar
Bilazaurus
But isn't the rocker cover bolted to the block? The coil boilt is quite long.
Old Jan 30, 2017 | 05:45 AM
rancor's Avatar
rancor
No the bolts do not go through the brass inserts are just long.
