Hard starting
Old Apr 1, 2017 | 08:14 AM
atambunan's Avatar
atambunan
Default Hard starting
i have a 06 Base and i have a hard time starting it and sometimes it won't even start, brought it to a mechanic they said it's the cam sensors replace driver and passenger side still didn't fix it, went onto changing the crank sensors as well, and still didn't fix it, i feel like it's fuel issues like it cannot get fuel pressure, if i get the car to start and turn it off it will start up right away, i was told fuel filter and fuel pressure regulator is built into pump and the fuel damper hardly goes out, so what could it be, would i need a new fuel pump
Old Apr 1, 2017 | 09:13 AM
dkmura's Avatar
dkmura
General & DIY Moderator
What codes are showing up? There's little point in just guessing.
Old Apr 1, 2017 | 10:41 AM
atambunan's Avatar
atambunan
there are no codes on
Old Apr 1, 2017 | 11:59 AM
dkmura's Avatar
dkmura
Are you checking for codes held in memory for both the ECM and BCM? What type of reader are you using?
Old Apr 1, 2017 | 02:06 PM
atambunan's Avatar
atambunan
Im using my mac tools scanner. there were no pending codes at all.
Old Apr 1, 2017 | 06:13 PM
dkmura's Avatar
dkmura
Surprised there were no codes at all. I dislike guessing, but from the symptoms you describe, my bet is insufficient fuel pressure at startup.
Old Apr 4, 2017 | 07:23 AM
CK_32's Avatar
CK_32
Wouldn't be the first time a pump has gone out on a Z..
Have the mechanic pressure test your injectors, check your A/F ratio.
That will be a lot quicker and a LOT cheaper than buying all of auto zones back stock chasing down a mystery in the fuel system.
Also check battery connection and voltage.
