No VDC Module
Old Sep 25, 2017 | 11:07 AM
Fletcher_z33's Avatar
Fletcher_z33
Default No VDC Module
Hi, I have an 04 350z and I was trying to find a way to eliminate TCS instead of pressing the button as it is still some what on. I opened my center console and there isn't a module there, I thought it was because I have TCS and not VDC (hence the VDC module not being there). I looked through other forums and threads but haven't found anything on how to completely disable tcs, any help? Thanks
Old Sep 25, 2017 | 11:24 AM
Fletcher_z33
The Yaw sensor is the one that isn't in my center console**
Old Sep 25, 2017 | 01:01 PM
karlt's Avatar
karlt
Simply press the button. TCS, unlike VDC, is either ON or OFF. There is no in-between state.
Old Sep 27, 2017 | 03:33 PM
Desert Z's Avatar
Desert Z
Check if you have a gray plug next to the brake fluid reservoir. If you do unplug it. This is what people with VDC do at the track to fully disengage the system (other than a manual switch).
Old Aug 24, 2018 | 02:50 PM
KRK.Z33's Avatar
KRK.Z33
So VDC is fully disabled when you press the TCS button?
Old Aug 24, 2018 | 04:28 PM
Franknbeans's Avatar
Franknbeans
VDC is never fully off with by turning off the TC button. From what I have read it turns it off 70%
I did this for my track days and it works out great.
Old Aug 31, 2018 | 05:28 AM
KRK.Z33's Avatar
KRK.Z33
So how would we go about making a switch if we have no yaw rate sensor module?
Old Aug 31, 2018 | 06:56 AM
MicVelo's Avatar
350Z/370Z Tech Moderator
Huge subsections on "complete disablement of VDC on 350Z" here:
https://www.google.com/search?q=disa...nt=firefox-b-1
Old Sep 3, 2018 | 04:46 PM
KRK.Z33's Avatar
KRK.Z33
I have searched hence how I ended up here. All of them mention of removing the yaw sensor or wiring up a switch to one. I do not have a yaw/g rate sensor under my center console by my shifter.
03 Enthusiast w/ TCS button. No VDC button, No Yaw/G Rate sensor.
Old Sep 4, 2018 | 03:32 AM
karlt's Avatar
karlt
The 03 Zs came in 3 flavors: ABS only, ABS with traction control only (TCS), and ABS with full stability control (VDC). If the button says TCS you have the middle setup, and pushing the button completely shuts off the traction control. ABS stays on. If the button says VDC you have the third setup and pushing the button will disable most, but not all, of the stability control. but again, ABS stays on. Only cars with stability control (VDC) have the yaw rate sensor.
