Looking for some help
Old Oct 14, 2017 | 06:06 PM
Eazdaskeez's Avatar
Eazdaskeez
Default Looking for some help
Hey you guys, I'm a member over at g35driver and I'm in the middle of an engine swap and I'm stuck on the torque converter bolts and was wondering if you guys could help me out.
Engine is pulled and the tc is still attached to the crank but I can't remove the bolts holding the tc on. I understand that you have to crank the engine to spin the flywheel to make the bolts accessible but I really can't fit a socket on the bolt from the starter space and the other side on the passenger side.
Yea I can't even fit a socket in there. Any ideas?
Old Oct 14, 2017 | 07:47 PM
James Duong's Avatar
James Duong
Lift up the tranny and undo the bolt from that opening from the tranny. 4 bolts.
Old Oct 14, 2017 | 07:49 PM
James Duong
Move all the bolts around untill you get all 4 bolts off.
Old Oct 14, 2017 | 07:50 PM
Atreyu'z 350's Avatar
Atreyu'z 350
You will need to get a Crawford wrench, like one of these.
https://www.google.com/search?q=3/8%...ih=925#imgrc=_
Old Oct 15, 2017 | 02:36 AM
Eazdaskeez's Avatar
Eazdaskeez
Thanks for the replies, I'll try to obtain the Crawford wrench today and update this post. This has been a bit nerve wrecking because this is my first engine swap so everything is making me nervous lol
Old Oct 15, 2017 | 04:11 AM
Eazdaskeez's Avatar
Eazdaskeez
Ok even with that tool I can't access the bolts. It has to be something I'm missing. Any other ideas?
Old Oct 15, 2017 | 09:24 PM
James Duong
Theres a big *** opening down there
bro i told you. Go on the under side of that motor. Theres an area for your socket to go in there
Old Oct 15, 2017 | 09:26 PM
James Duong
Well you have to spin the torque converter around untill you see in in that area. I just went through this last week
Old Oct 16, 2017 | 02:22 AM
Eazdaskeez's Avatar
Eazdaskeez
Thanks I'll take a look today when I get home
Old Oct 16, 2017 | 01:57 PM
Eazdaskeez's Avatar
Eazdaskeez
Found it guys thanks!
Old Oct 16, 2017 | 04:00 PM
Atreyu'z 350
Don't thank me. Thank James.
