I got clutch fluid in my eyes and I threw my clutch slave cylinder, is it broken
Old Dec 24, 2017 | 07:01 PM
Moe747's Avatar
Moe747
Default I got clutch fluid in my eyes and I threw my clutch slave cylinder, is it broken
I ****ed up. I was changing the clutch line and as I had my clutch slave cylinder out and disconnected I pressed the piston or the thing that retracts and extends out and the thing squirted clutch fluid in my eyes. I cussed and dropped the thing without hesitation and ran to wash my eyes out with water. When I came back I installed the new line, slave cylinder and everything went well. I checked my fluid and the reservoir was empty so I filled it up with brake fluid. I had my brother try and help me bleed the air out and I couldn't get the clutch to react normally, it always snaps in or out. So then I decided to open the bleeder valve and press the slave cylinder in with my hand and that fluid came out from inside the boot and this is where I'm at now. This is an external slave cylinder btw, 2003 350z.
Old Dec 25, 2017 | 03:21 AM
Conway_160's Avatar
Conway_160
Sounds dck'd to me. Order a new one off of rockauto it's like $20.
Old Dec 27, 2017 | 01:00 AM
terrasmak's Avatar
If you have fluid in the boot, the piston is most likely toast. Rebuild or replace
Old Dec 27, 2017 | 06:41 AM
Z33Garage's Avatar
Z33Garage
Replace it, they are cheap enough.
sherm
Apr 11, 2020 05:21 PM
adamgfn
Drivetrain
Sep 25, 2015 10:52 AM
e30cabrio
Drivetrain
May 8, 2014 08:30 AM
hackermb
Sep 14, 2009 04:33 AM
