I got the wrong clutch in the mail!?
So I order a stage 3 clutch from my 350z hr but ended up getting a 370z hr stage 3 clutch does anyone know if the clutch would fit, my 350z or just send it back ? Some one reply ASAP thanks
350Z/370Z Tech Moderator
If you haven't already done so, since you seem to feel you "need" a Stage 3 clutch, would suggest you look into a new SMF versus the DMF so equipped. It is difficult, if not impossible to re-surface a DMF *properly*.
A highly sprung and harder friction material clutch is useless without the proper flywheel surface to take advantage of the high clamp and friction rates. Matching components now will save you the trouble of dropping the tranny a second time to replace it later on.
Same with the hydraulic feeding system, Master, CSC, feed lines.
