350z Clutch Adjustment
Old Feb 25, 2019 | 02:56 PM
CK_32's Avatar
CK_32
Default 350z Clutch Adjustment
Does anyone know the OEM clutch master cylinder travel specs?
i feel like my master cylinder isn’t in adjustment with the new JWT clutch installed.
Also can you guys measure your clutch master travel distance? My sht literally is almost on the firewall after full travel. From what I found OEM says it should be 80mm (3.5”) off the floor to the clutch pedal face...
Old Feb 26, 2019 | 03:52 AM
Heel Til I Die's Avatar
Heel Til I Die
Maybe this will help?
https://www.google.com/url?sa=t&source=web&rct=j&url=http://www.jimwolftechnology.com/wolfpdf/350ZCLUTCHADJUSTSPECSHEET.pdf&ved=2ahUKEwiM6PTbt9ngAhUE4oMKH QuCBOwQFjAAegQIARAB&usg=AOvVaw2wGrYpWUTYLql3DLW2GK1b&cshid=1 551185475958
File Type: pdf
Old Feb 26, 2019 | 04:31 PM
CK_32's Avatar
CK_32
Not really. The H2 adjustment on the pedal diagram is what I’m asking people to compare with. Like I said per those notes they want 2-4” off the firewall travel distance.
My pedal in thag position bsaically almost touchesthe firewall carpet. Maybe 1” off of that.
Also I’m trying to look for the Nissan travel spec of the clutch master cylinder. See if my travel at the fork is correct.
cheeyo
Jan 13, 2016 04:40 PM
350z 6spd
Drivetrain
Mar 17, 2013 01:38 PM
350GT350Z
Sep 26, 2007 08:58 AM
