Oil pressure low?
Old Apr 30, 2019 | 03:57 PM
fsu747's Avatar
fsu747
Default Oil pressure low?
Installed new plugs, coils, valve covers. Oil pressure was great at first, but now it's almost at zero when idling. Also, now there is a loud rattle noise like valves or something? Any help or ideas would be great. Initially had oil in the spark plug tubes with multiple cylinder misfires. Someone tried to use gasket seal on the seals for the tubes. Scraped all that off and installed new covers.
Old Apr 30, 2019 | 06:17 PM
jellofuel's Avatar
jellofuel
Sounds like the oil galley gaskets are blown. I would advise getting the car diagnosed asap, as this will ruin the engine. It already sounds fairly serious, and I'm surprised it hasn't thrown a code yet.
https://www.z1motorsports.com/front-...et-p-9460.html
Old May 2, 2019 | 10:45 AM
fsu747's Avatar
fsu747
Thanks, taking it to the shop today. Seems like this happens quite a bit with these motors since they put those cheap paper gaskets in from the factory.
Old May 5, 2019 | 07:32 AM
Chihuahuamaster's Avatar
Chihuahuamaster
If the gallery gaskets actually turn out to be your problem, I would advise you to lookup the 'EPS Tuning Gallery Gasket Kit.' These are metal reinforced gaskets made to correct this issue. Although I do not know if this kit is the same for both de and hr engine types.
Whereas using the OEM gaskets will result in the same failure at some point in time.
Old May 16, 2019 | 03:35 AM
813_350Z's Avatar
813_350Z
How much of a time frame are we speaking of here? Unfortunately, as you probably know, these engines are notorious for burning oil.
However, mine had a small leak from the lower oil pan gasket on the passenger side. It was initially so small that I barely noticed oil on the garage floor. It eventually grew to a steady drip anytime that the engine was running. I would ensure that you don't have any additional leaks from either the upper or lower oil pan.
0taku
Sep 9, 2022 03:55 AM
Andres_Miami
Apr 12, 2019 09:51 PM
Perezbrandon54
Feb 27, 2019 07:05 AM
lealjose1993
Feb 17, 2019 07:33 AM
Drakson Colina
Feb 10, 2019 08:06 PM
