350z oil leak
Old Feb 23, 2019 | 07:14 AM
Mark A Leone's Avatar
Mark A Leone
Default 350z oil leak
Hello all!
question for you.
is there a specific part of the 04 Nissan 350z engine that leaks oil?
something very common?
Old Feb 23, 2019 | 07:16 AM
travlee's Avatar
travlee
Master
The motor
Old Feb 23, 2019 | 09:25 AM
Spike100's Avatar
Spike100
I have a 2003 350z and the car was leaking oil at the valve covers. I replaced the valve covers (and of course the gaskets). The car had about 120k miles at the time.
Old Feb 25, 2019 | 04:58 AM
OldManZFL's Avatar
OldManZFL
In addition to the valve covers, the O-ring on the oil filter likes to go bad. Fairly easy fix
Old Feb 25, 2019 | 06:27 AM
dkmura's Avatar
dkmura
General & DIY Moderator
This really depends on the quality of the oil filter. I've NEVER had an O-ring go bad on the OEM, Mobil 1 or K&N oil filter in over 16 years with the Z33.
Old Feb 25, 2019 | 09:45 AM
OldManZFL's Avatar
OldManZFL
Very true, i started going with "cheaper" alternatives in 2017, 14 years without an issue and all of a sudden it started leaking.
Old Feb 25, 2019 | 09:59 AM
coletrickle74's Avatar
coletrickle74
Highly recommend opening the hood to look.
Old Feb 25, 2019 | 02:07 PM
jhc's Avatar
jhc
General & Tech Moderator
Look at valve covers, then EGR valve and hosing. Obviously start looking at the bottom and follow upwards with very good light.
Old Mar 7, 2019 | 05:54 AM
Cracka350's Avatar
Cracka350
Alright alright...
Old Apr 5, 2019 | 10:27 AM
Johnyrocket's Avatar
Johnyrocket
Check the gasket behind the Oil Cooler.
Old May 16, 2019 | 03:47 AM
813_350Z's Avatar
813_350Z
Originally Posted by travlee
The motor
Oh man, Travlee. I haven't seen you since that kid tried to buy the "1000 hp" Z with the fake dyno sheets! Then again, I haven't logged in in 3 years. lol.
ANYWAY, Travlee is 100% spot on!
Unfortunately, seals on this motor might as well be non-existent. I've had leaks on my seals on my spark plug wells, the valve cover rings, and the lower oil pan gasket. I always keep a backup set of valve cover seals because I've replaced them 3 times in the 8 years I've owned my Z.
Old May 16, 2019 | 05:08 AM
travlee's Avatar
travlee
Master
ha, yep still here and still sarcastic
zKid350z
Dec 12, 2016 10:26 AM
joeyvq27
Oct 13, 2016 01:59 PM
AgentReaver
Apr 29, 2016 02:11 PM
BRICKS Z
May 5, 2003 08:41 AM
