Transmission noise whine
Old Oct 27, 2019 | 06:27 AM
Jacolby Baker's Avatar
Jacolby Baker
Default Transmission noise whine
So I know there’s going to be a little whine and it’s normal that’s not the whine I’m talking about. This is like a grinding whine at the same time. It’s weird any ideas I have the video. It’s only in first when accelerating and decelerating. First works fine tho and so do all other gears. The go into each smoothly and without a problem. Could it be the diff? In the video you can hear it in second a little if I’m hearing it right but nothing like first.
Last edited by Jacolby Baker; Oct 27, 2019 at 06:28 AM. Reason: I don’t see attachment
Old Oct 27, 2019 | 08:11 AM
mr. sparco's Avatar
mr. sparco
Does it have a different final drive that was installed into the rear diff? If installed improperly the whine can be quite noticeable. Change out the rear diff fluid and see if that helps, could be low or not have the correct fluid as well.
meezusthegoat
Dec 13, 2016 05:28 AM
Daytondakid13
Dec 16, 2012 03:25 PM
nofrey
Dec 1, 2011 07:01 PM
Flimsy
Aug 17, 2011 10:46 AM
JPsZ
Aug 10, 2010 04:39 AM
