350z DE - AT transmission problems
Old Feb 2, 2020 | 03:15 PM
Ramon Suzan's Avatar
Ramon Suzan
Default 350z DE - AT transmission problems
Hi, I have a 350z 2005 DE Automatic, I use my car in track day.
some days ago, when i use the “semi automatic shift” , the gear starts to enter in Drive automactily.
i don’t know what is happening, could you help me?
what can I do to fix it?
Old Feb 2, 2020 | 11:48 PM
813_350Z's Avatar
813_350Z
Error Codes?
Your manual switch could be out or about to go out
Old Feb 3, 2020 | 07:23 AM
jhc's Avatar
jhc
General & Tech Moderator
So we're clear-
Are you speaking of moving your shifter to the right gate for "Manual Mode?" And then it continues to shift without moving the lever?
As stated above, see if you have codes. If what I describe is accurate you have 2 choices -
1) Start taking things apart, looking for loose fasteners or missing pieces. (or faulty shift switch ).
2) Seek professional help. If you are a novice this may be your best choice. Gl!
Skywalker21
Jul 27, 2022 01:16 AM
RROBFEST
Puerto Rico
Apr 11, 2013 11:37 PM
KamiSpeed
Mexico
Aug 20, 2010 02:25 PM
fastmike
Europe
Apr 10, 2004 10:57 AM
