06 Manual PS Rack + PS Pump Replacement after finding metal, need help
Old Oct 20, 2020 | 06:58 AM
Cody Huseby's Avatar
Cody Huseby
Default 06 Manual PS Rack + PS Pump Replacement after finding metal, need help
06 350z Manual, steering went out and found tons of metal shavings in the PS fluid. Was told to replace both the pump and rack due to potential contamination. Ouch.
Anyone know if I need to change the associated hoses as well? How about the reservoir? The PS cooler?
https://www.z1motorsports.com/power-...0z-p-9121.html
There is a "set" on Z1, but at a whopping 625$ thats more than the rack or the pump. That cant be right can it? Thats puts this repair at over 2,500 just in parts, if I do the labor myself.
Old Oct 20, 2020 | 10:59 AM
DarkZ03's Avatar
DarkZ03
You could flush out the lines and reservoir if you are meticulous about it. I'm in the camp of replacing it all with stuff like that, but if you remove the line and reservoir and rinse them out with clean fluid and compressed air you should be ok.
Omisfer
Oct 2, 2017 10:51 AM
codek
Nov 10, 2010 01:16 PM
TittieZ
Sep 18, 2009 11:54 PM
