Is my Catch Can Hose too long?
Old Mar 2, 2023 | 04:34 AM
フェアレディZ's Avatar
フェアレディZ
Default Is my Catch Can Hose too long?
Hey guys.
I'm installing a catch can after swapping in new valve covers. Maybe a dumb question, but is my hose too long? I was trying to run it in a way where it would rub on as little things as possible, but I don't know if the length of it could negatively affect anything. Thanks!
Old Mar 2, 2023 | 05:02 AM
Heel Til I Die's Avatar
Heel Til I Die
Looks fine to me. I have a similar setup but routed to an open breather. I mounted it to the front as well so that the cover would conceal it to avoid questions for annual inspections.
The hose is probably not as long, but as long as it's not kinked or in any danger of melting, you should be fine.
Old Mar 2, 2023 | 05:58 AM
tuzzio's Avatar
tuzzio
While the length of the hose ultimately doesn't matter or negatively effect anything, you could always get a 90 / 135 / 180 degree fitting and definitely change the routing to be much shorter if it actually bothers you.
Old Mar 2, 2023 | 07:30 AM
i8acobra's Avatar
i8acobra
I'd get a 90 degree fitting. BTW, that "Supreme" sticker is probably taking away about 5 or 6 HP. I'd remove it immediately.
Old Mar 2, 2023 | 08:59 AM
フェアレディZ's Avatar
フェアレディZ
You're the best, thank you so much!
Old Mar 2, 2023 | 09:00 AM
フェアレディZ's Avatar
フェアレディZ
Yeah but having Rem on the sticker adds 10. 😉
Cosmic z
Jul 9, 2019 06:41 PM
CNunes_95
Jul 15, 2015 06:26 PM
Feb 3, 2013 02:06 PM
350Z400rwhp
May 22, 2008 06:33 PM
norapat01
Dec 4, 2007 12:34 AM
