Unorthodox Racing Pullies
Old Mar 3, 2004 | 02:17 PM
EnthuZiast's Avatar
EnthuZiast
Guess whose back, back again...
Default Unorthodox Racing Pullies
Anyone have these?
If so did you notice a difference?
If so where is the cheapest place to buy some?
Old Mar 3, 2004 | 02:34 PM
wren57's Avatar
wren57
Everything I have read says that the crank pulley gives the power and that the other two (alternator and power steering pump) are just for show. This is why I bought a crank pulley.
PM sent
Old Mar 3, 2004 | 02:55 PM
EnthuZiast's Avatar
EnthuZiast
Thank you!
Old Mar 3, 2004 | 02:58 PM
wren57's Avatar
wren57
Your PM box if full, but I sold my crank pulley anyway.
Old Mar 3, 2004 | 03:20 PM
EL Diablo's Avatar
EL Diablo
great Performance mod.
like mentioned you just need the Crank Pulley
Performance Nissan has it for 205 bucks
Old Mar 3, 2004 | 04:24 PM
Spec_Tacular's Avatar
Spec_Tacular
Some should find out if the stock crank pulley is harmonic. If it is a lightened crank pulley is not a great thing to do.
Old Mar 3, 2004 | 04:28 PM
wren57's Avatar
wren57
It has been found out, and the topic has been beaten to death. The pulley does NOT compromise engine longevity.
Old Mar 3, 2004 | 04:32 PM
jesseenglish's Avatar
jesseenglish
That's a pretty bold statement. I don't want to argue this again because there are plenty of threads about it on this forum. Bottom line, there is no proof either way.
Old Mar 3, 2004 | 04:51 PM
westpak's Avatar
westpak
SFZCC
I just got one and will try to have it put on tomorrow.
I got it from Concept Z, the yhad the best price at 220 including the belts, the Performance Nissan price is minus the belts. http://conceptzperformance.com/Cart/...68.158.232.166
Old Mar 3, 2004 | 04:52 PM
Z CRUZN's Avatar
Z CRUZN
Default Pulleys....
After reading tons of posts on the subject of UR pulleys I went ahead and installed them last week. Yes, the crank pulley makes all the difference and the other 2 (alt & W/P) are mostly for show although they are much lighter than the OEM's. So, unless you want the 3 installed for looks, I'd suggest going with just the crank pulley - the alt pulley is a job. I didn't remove the alt - used a chain wrench to hold the inside of the pulley while unbolting with the rachet. In fact, that's how I did the crank pulley - worked like a charm!
Anyway, the result was pleasing in both appearance & performance. The car is much smoother from a stop, the quickness is noticable at 3k+ RPM's, and the RPM's definitely rap up quicker. Super fun! Just waitin' now for the Crawford headers and hi-flo cats - savin' a few $$ for that. Here's few photos of the pully-changing day.........
Old Mar 3, 2004 | 04:54 PM
Z CRUZN's Avatar
Z CRUZN
Default Installed pulleys....
top side view
Old Mar 3, 2004 | 04:55 PM
Z CRUZN's Avatar
Z CRUZN
Default UR pulleys....
underneath view
Old Mar 3, 2004 | 04:57 PM
Z CRUZN's Avatar
Z CRUZN
Default tool....
Used the chain wrench with cut belts to hold the pulley, then used a wrench to loosen bolts........
Old Mar 3, 2004 | 04:58 PM
Z CRUZN's Avatar
Z CRUZN
Default and engine bay.....
Engine bay so far......
Old Mar 3, 2004 | 04:59 PM
Z CRUZN's Avatar
Z CRUZN
Default engine bay
driver's side view
Old Mar 3, 2004 | 05:10 PM
EnthuZiast's Avatar
EnthuZiast
My Inbox should not be full.
Very helpful posts. Thank you to everyone.
Old Mar 3, 2004 | 09:13 PM
EnthuZiast's Avatar
EnthuZiast
Anyone have a dyno for this mod?
Old Mar 3, 2004 | 09:17 PM
wren57's Avatar
wren57
I know a few members have dyno'd and it showed ~ 6rwhp across the board...
Old Mar 3, 2004 | 09:22 PM
EnthuZiast's Avatar
EnthuZiast
damn...thats impressive.
Wren,
Are you of the school of thought that this will eventually be negated by the ECU? Some argue that but I just dont see it.
Will you look at this link and tell me if it has everything I need? Also what do you think I should pay to install this?
220 including the belts, the Performance Nissan price is minus the belts. http://conceptzperformance.com/Cart...268.158.232.166
Thanks,
Tom
Old Mar 3, 2004 | 09:45 PM
wren57's Avatar
wren57
The ECU can NOT compensate for this. The ECU can only control air/fuel mixture. This is a inertia-reducing mod, the ECU has nothing to do with it. $220 for everything is a good price, but I would hold out to get one used. Two just sold in classifides for $125. If you get it installed, expect to pay $100 or so. You should do it yourself, as it is a fairly easy DIY, and saves money. Plus it gives you an excuse to buy a breaker bar. Let me know if you have any more questions.
