U/R Crank Pulley INSTALLED: Review/Writeup Inside !
Old Mar 18, 2004 | 10:31 PM
wren57's Avatar
wren57
Thumbs up U/R Crank Pulley INSTALLED: Review/Writeup Inside !
Did it in about 2 hours, taking my time. I actually made a friend during the install (guy came up and started talking to me), so I kinda too my time with the install and talked to him more than actually working on the car. I honestly had little idea what I was supposed to do when I started in on the install, and at a few points I was ready to give up. The 12mm bolts on the bottom of each tensioner pulley are a B!TCH to get to from the top of the engine bay. Eventually I got it all together, and best of all, no squeal on startup, just a tad bit of squeal on a uturn I made, any ideas on this? I highly recommend this mod, I feel a slight increase in power, and lots better idle/takeoff and better throttle response. Great product, and great DIY project for someone who isn't afraid to break into their motor.
PS: Get some mechanix gloves for this. My hands look like they've met a weed eater...
Old Mar 19, 2004 | 12:41 AM
menace_z's Avatar
menace_z
just a question do i need a new pulley belt if i were to just install a crank pulley?? cause i know i need the belt if i get the pulley ss kit just wondering cause i only want the crank don't need the other
Old Mar 19, 2004 | 01:24 AM
teh215's Avatar
teh215
Yes, you need new belts.
Old Mar 19, 2004 | 01:38 AM
ypwpat's Avatar
ypwpat
is there any changes in Noises from inside or outside? Either when idle or Driving?
Old Mar 19, 2004 | 05:56 AM
Apexi350z's Avatar
Apexi350z
Charter Member #50
no noise change from inside or outside..
Old Mar 19, 2004 | 06:37 AM
EnthuZiast's Avatar
EnthuZiast
Guess whose back, back again...
Is a $80.00 a fair labor quote for this mod.
What size belt did you use?
Old Mar 19, 2004 | 07:43 AM
al503's Avatar
al503
I don't think $80 is out of the question. However, any mechanic with a lift and the proper tools could do this in a half hour IMO.
Old Mar 19, 2004 | 07:56 AM
ChrisMCagle's Avatar
ChrisMCagle
Default Kinda hard
I did the pulley swap-out at home too. It was a beeeeotch to get that crank pulley bolt off! I actually followed the instructions provided by U/R with the pulleys and removed the radiator fan (which also required removing the bottom hose to the radiator.... VERY messy). With the fan off you have A LOT more room to get at things. I actually don't see how you could do the install with the fan there.
I didn't really notice any difference in sound or performance, but they sure do look nice. Maybe a real dyno would show an increase, but the butt-dyno registered a "0".
-Chris
Old Mar 19, 2004 | 09:26 AM
wren57's Avatar
wren57
Heh, yeah, I didn't remove the fan. It was crazy, I am glad I had some short 12mm wrenches for the two underside tensioner bolts. I had to pull contortionist moves to reach them, and then I'd turn until I got tired of turning, and chat with my new friend for a while. I honestly don't know how I did it either.
There is zero noise change from inside, outside, or in the engine bay.
I would NOT pay $80 for someone else to do it, even if I had the $80 to spend... being brokeass college student does have its disadvantaged. Then again, it IS friday night, so there are advantages too.
As for my slight squeeling when I made a uturn, any ideas on that? Do I need to tighten/loosen either belt, and if so, which one? Thanks.
Old Mar 19, 2004 | 09:32 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Your belt just prolly slipped for a sec, I wouldnt stress over it. I would say it is a little loose, re-tighten it in a few days....
Old Mar 19, 2004 | 09:37 AM
PoWeRtRiP's Avatar
PoWeRtRiP
Default Re: Kinda hard
-Chris
i felt the difference on mine about a week after install. all of a sudden it was like whoa this is different. i felt this mod made as much of a difference as my test pipes did. how long have you had yours on?
Old Mar 19, 2004 | 11:05 AM
ChrisMCagle
Default Re: Re: Kinda hard
Well, I installed the pulleys... then about 2 weeks later I installed the KINETIX plenum, then took it off and put the stock back on (small leak in seal with KINETIX plenum). I installed the KINETIX cats about 2 days later, then about 4 days after that, I put the KINETIX plenum back on.
Out of the 3 mods, the plenum is really the only one that I immediately "felt" a difference with. The cats make a nice sound, but I don't notice any performance gain (although that's not to say one doesn't exist).
It's possible that since I installed all 3 within a short period of time, I am feeling the effects (gains) of all 3 combined rather than individually? The pulleys sure look nice though!! I just wish I could figure out a way to swap out the alternator pulley. I only got the crank and the other one installed.
-Chris
3vilbunny
Jul 18, 2017 05:10 PM
Fixxxercask
Nov 9, 2015 11:10 AM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
