Next mod
Old Mar 19, 2004 | 10:18 PM
NVthis350's Avatar
NVthis350
Default Next mod
Well, i have been adding mods onto my car every couple months, but now i am not sure which mod should i get. I am torn between the UR crank pulley, high flow cats or an intake plenum. I already have intake, borla exhausts and ground kits. Any suggestions oh wise ones?? thanks in advance...
Old Mar 19, 2004 | 11:15 PM
EL Diablo's Avatar
EL Diablo
Torn between the UR Crank Pulley, high flow cats, or an intake plenum.
Get them all
Problem solved
Old Mar 19, 2004 | 11:31 PM
dmbshu's Avatar
dmbshu
from what i've read, upgraded plenum is an excellent choice
they say it definitely gives you a noticable increase in power
just my thoughts
Old Mar 19, 2004 | 11:58 PM
isalvus's Avatar
isalvus
go with the ur pulley, than get the plenum i think you will be happy good luck!
Old Mar 20, 2004 | 09:13 AM
ares's Avatar
ares
Veteran
all3 are good. eventually you will get all 3 I assume?
Id go with the cats first, cause not only do you get the power, but it has the most sound as well. if that interests you.
Old Mar 20, 2004 | 10:11 PM
NVthis350's Avatar
NVthis350
Thanks so much for all the input
Stevo Z
Oct 3, 2015 09:14 PM
Dymsi
Sep 29, 2015 11:32 AM
Tochigi_236
Sep 27, 2015 03:40 PM
