Who sells differential fluid?
Old Mar 29, 2004 | 10:55 AM
zfastest's Avatar
zfastest
Question Who sells differential fluid?
Anybody have any reccomendations? I just got the Nismo LSD Pro installed and going through the break in procedures. It says to change the diff fluid after breaking it in, not a bad idea considering what I'm going to be doing to it soon.
So...any retailers out there sell the Nismo 80/90 fluid it comes with? Or have something better? I'm looking to purchase some asap.
Old Mar 29, 2004 | 11:18 AM
PoWeRtRiP's Avatar
PoWeRtRiP
royal purple is available at pepboys, arguably the best one of the best fluids out there!
Old Mar 29, 2004 | 11:29 AM
Z CRUZN's Avatar
Z CRUZN
Default Available.........
I know Mobil 1 synthetic 75w90 is available @ Auto Zone & Advanced Auto. I'm using that w/ the GM limited slip additive next week when I do the diff. oil change. Was going to use Redline SuperLite Shockproof w/ the GM additive, but hard to find around here. Several Z-fellas recommended the Mobil 1 w/ the GM additive - good combo in their opinion. Since I only have the stock Z LSD, it should be sufficient.
Old Mar 29, 2004 | 10:31 PM
350ed's Avatar
350ed
Professional
Default Re: Available.........
Where do you get this GM additive? What's it' about?
Thanks.
Old Mar 30, 2004 | 02:39 AM
Z CRUZN's Avatar
Z CRUZN
Default LS additive............
The additive is just a little extra insurance for the rearend - helps reduce chatter and noise, reduces plate friction. A similar type additive comes in most Redline gear oils. The GM version can be purchased at most GM dealerships ($6-7). Part #1052358. Is it neccessary on a stock LSD? - No Is it cheap insurance for peace of mind? Yes Kinda like me doing an alignment check at every other oil change...neccessary - maybe not for peace of mind after buying $1000 tires - yes!
Just my opinion.....
Old Mar 30, 2004 | 04:08 AM
j's350z's Avatar
j's350z
I could shipp you redline form NJ but you are probably better off just going to redline's website and finding a local dealer. If you can't them PM me and I'll get you some..
Jason
Jason@racemrc.com
Old May 10, 2004 | 02:52 PM
NY 350Z's Avatar
NY 350Z
im gonan go with the royal purple 80/90... is it ok if i add the GM stuff even after a couple days of changing the diff oil?
alos how many quarts of either one did you use?
Old May 10, 2004 | 05:23 PM
Z CRUZN's Avatar
Z CRUZN
Default LSD oil..........
Uses almost 2 qts. of oil (about 1 3/4)......and yes, you can add the additive afterwards, tho I've always added it at the time of change in my cars
Old May 10, 2004 | 05:50 PM
dwnshift's Avatar
dwnshift
We use Mobil1 75-90 syn in our GAC cars.
Old May 10, 2004 | 06:24 PM
NY 350Z's Avatar
NY 350Z
i did it tonight. went to pep boys, they didnt carry royal purple. so i got the mobil 1 75-90. extremely easy to do. the noise that i had went away also so thats good. the old oil was BLACK and very chunky-like aroudn the drain plug. also it didnt look like there was alot int here to begin with.
how often are you guys gonna change the diff oil?
Twenty4
Jan 17, 2016 01:20 PM
