MT tranmission fluid and differential fluid
Old Apr 5, 2004 | 11:12 PM
JasZ's Avatar
JasZ
Default MT tranmission fluid and differential fluid
Does anyone know if the MT fluid and differential fluid Nissan uses in the Z is synthetic?
Is Royal Purples MaxGear fluid as good as their engine oil, or is there a better brand to use for MT fluid and differential fluid?
Thanks,
JasZ
Old Apr 5, 2004 | 11:39 PM
ssk0771's Avatar
ssk0771
DO NOT USE ANYTHING OTHER THAN THE NISSAN MT FLUID.
NO ONE ELSE MAKE 75-85. THE ONLY OTHER ONE I WOULD RECOMEND IS REDLINE 70-80.
Old Apr 6, 2004 | 06:36 AM
JasZ's Avatar
JasZ
The car manual says we can use 75W-90 and the MaxGear has fluid with that rating. Why would you have to use the Nissan stuff ?
Is the Nissan stuff synthetic?
Thanks,
JasZ
Old Apr 6, 2004 | 11:09 PM
ssk0771's Avatar
ssk0771
Thanks,
JasZ
I would recomend Original Nissan if not Red Line 70-80w. I use Royal Purple 75-90 and another type ( I think it was Valoline, Dealer put it in) in my previous Z and it made my gear really sticky and made the grind worse. I used Red Line after that and it was pretty good. I have played around with few different type of tranny fluid because of my grind and knochy issue on my previous Z and OE Nissan and Redline 70-80w was the best.
OE Nissan MT fluid is not synth.
Just my opinion and what I experienced.
Old Apr 7, 2004 | 07:56 AM
JasZ's Avatar
JasZ
I have been reading up a bit on this and the only thing that I noticed that might be a problem with the the GL-5 Royal Purple was the EP additives that could corrode copper sync parts, but their product info says their additives are non-corrosive as does Redline's. I've heard other people praise the RP tranny fluid, but I'm trying to be careful before doing this.
Thanks for your help.
Old Apr 7, 2004 | 01:01 PM
ssk0771's Avatar
ssk0771
You are absolutly right. That is why you should use the OE Nissan MT Fluid or Redline 70-80w (GL4 also).
lapham3
Oct 7, 2022 03:15 PM
burglapfd
Dec 6, 2020 01:04 PM
1973camarolt
Drivetrain
Oct 11, 2015 01:26 PM
