Injectors look weird!!!!!!!!
Old Apr 22, 2004 | 03:17 PM
denic79's Avatar
denic79
Default Injectors look weird!!!!!!!!
I removed my top engine cover and I was looking at my injectors. It looks like there all wet and there is debris all over them. But there isn't gas leaking out or anything. Has anybody seen this problem. Check to see if yours are the same.
Old Apr 22, 2004 | 04:59 PM
peptidbond's Avatar
peptidbond
That is not too surprising. If you look at the front of the engine, you will notice that there is an openning to the under side of the plenum (where the injectors are). Debri and water should be able to get in there from driving. Once in, it probably won't come out on its own. Just normal dirt. Now if you smell gas, that is another story.
Uriyo_
Sep 8, 2021 08:46 AM
kyin
Oct 15, 2015 05:54 AM
