Xerd&Borla TD...not enough backpressure?
Old Apr 28, 2004 | 01:34 AM
Dom's Avatar
Dom
Default Xerd&Borla TD...not enough backpressure?
I have long tube headers and the Borla TD installed.
I think that the very low backpressure takes some hp from the
system.
From runs I had before the headers and after I can only say that
there is no improvement in acceleration.
I think either NA and SC applications need some backpressure for
maximum hp output.
Only Turbo engines run the best with 0 backpressure.
Any ideas?
Old Apr 28, 2004 | 05:04 AM
PoWeRtRiP's Avatar
PoWeRtRiP
how long ago did you install? it takes a few days sometimes to adjust for the additional air flow. i like the effect of my xerds and injen and think it made a huge difference in mid range power
Old Apr 28, 2004 | 06:06 AM
Dom's Avatar
Dom
I installed them some time ago. I ran about 800miles on the racetrack since then.
The mid range is exactly where I think I lost some power.
Old Apr 28, 2004 | 06:09 AM
PoWeRtRiP's Avatar
PoWeRtRiP
do you have any way of controlling your a/f. my car was losing power due to the knock sensor pulling timing from it running lean. ever since i installed my afc and tuned, it feels much better now. have you dynoed?
Old Apr 28, 2004 | 06:52 AM
Dom's Avatar
Dom
Haven't dynoed.
Tuning an SAFC is not that easy in here. I'd like to have it done however.
Maybe I should send the ECU to TS. That would be the easiest.
Do they adjust the fuel settings or just care for timing and rev limit?
Old Apr 28, 2004 | 07:17 AM
FritzMan's Avatar
FritzMan
Default Re: Xerd&Borla TD...not enough backpressure?
Originally posted by Dom
...Only Turbo engines run the best with 0 backpressure.
Any ideas?
I believe every setup needs backpressure. In the case of turbos, the actual turbines to the turbo typically provide adequate backpressure.
Old Apr 28, 2004 | 07:25 AM
Dom's Avatar
Dom
Default Re: Re: Xerd&Borla TD...not enough backpressure?
...talking about backpressure from exhaust systems.
Old Apr 29, 2004 | 11:45 AM
Street Visionz, Inc.'s Avatar
What is the diameter of the piping where the xerd connects to the y-pipe? Let's say I have 2.5inch piping throughout my exhaust all the way to the cats, then when the xerd replaces the cats will it fit?
Old Apr 29, 2004 | 11:54 AM
PoWeRtRiP's Avatar
PoWeRtRiP
I believe the collectors are 2.25" and the primaries are 1.75"
JjL
East Canada
Jun 12, 2019 03:04 AM
jsunly
Sep 19, 2015 01:22 PM
TXSTYLE
Jun 24, 2003 10:35 AM
