Clutch And Flywheel Ideas........
Old May 2, 2004 | 06:22 PM
esemes's Avatar
esemes
Default Clutch And Flywheel Ideas........
okay, i am ready to get into clutch ideas....
wants:: a lighter flywheel , that (results) will perform better than oem, BUT will not be insanely noisey (cement truck)...
i have heard the tilton (at 8lbs!?!?!) is spinning up ultra fast and hard, but makes some pretty serious churning/chattering sounds....
i want to maintain as much of the g35 near-luxo feel/sound as possible, but will sacrifice some of it....
what's the ideal weight over the stock fly?? (oem = 40+lbs??)
and, what type/brand should i go with (vortech kit will be here this coming week, fujitsubo exhaust sometime before christmas (lol-NOT)
thanks, as usual
-eS
Old May 2, 2004 | 06:41 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
teh stock clutch AND flywheel together weighs a tad over 45 lbs....
stock flywheel is 23 lbs. I had the Unorthodox one in my car for a little while (just removed as I have a new ATS clutch/flywheel combo coming), and despite its weight 912 lbs), it was not significantly louder that stock.
Old May 2, 2004 | 07:55 PM
UsafaRice's Avatar
UsafaRice
Holy crap! 912 pounds! You running a diesel engine?
Anyway... Does anyone know how much torque the stock setup will handle? Will a Vortech or ATI at high boost still be ok?
Old May 3, 2004 | 11:29 AM
G3po's Avatar
G3po
Default ATS
The ATS twin disc "flywheel +clutch" ~ 25lbs.
So Z1 would you rate the ATS as "very" streetable?
Does anyone sell it for under $2k.
Old May 3, 2004 | 01:12 PM
Diesel350's Avatar
Diesel350
Have you looked at the JWT flywheel/clutch for under $800. I think it handles about 600hp.
Old May 3, 2004 | 01:46 PM
G3po's Avatar
G3po
Default clutch /FW combo
The JWT is definately under consideration.
Just thinking how futre proof I want to be.
I do intend to build up the bottom and with TTs
all in one shot, so >600 crank is well within possiblity.
Old May 3, 2004 | 03:10 PM
esemes's Avatar
esemes
so the JWT combo is strong, and not overly loud (mixer sound i hear so often mentioned)??
Old May 3, 2004 | 03:27 PM
Z1 Performance
Former Sponsor
I would rate the twin as very streetable yes - ask Skidazzle - he recently got one from us.
The triple is even easier to drive, though admittedly more clutch than anyone realistically needs.
Old May 3, 2004 | 03:33 PM
esemes's Avatar
esemes
any leads on where to shop for one??? (my car has just turned 500 miles, and i plan to go vortech this month; the unit arrives this week)..
i wanna have all my ducks lined up......
((now, wh's gonna hook me up w/ a fujitsubo exh. and Y???)) ... will pay good $$$
Old May 3, 2004 | 04:15 PM
G3po's Avatar
G3po
Default Clutch combo
For a Vortech setup , I would expect that something like the JWT combo ~$800 would be all you'd ever need.
I'd only consider spending the ~$2k for an ATS combo for a TT setup which can produce substantially more TQ out of the box and especially with re-worked internals (ie. lower CR +higher boost).
The Ceramic Tilton setup seems very well suited for the ulimate NA application were the lower interia makes a bigger diff overall.
Though for "streetablity" it still sounds "grabier than either a JWT or ATS combo. I'd love to use the Tilton dual carbon, but ~$3400 is just a little too high for may consideration.
Old May 4, 2004 | 02:20 PM
shortcut3d's Avatar
shortcut3d
All I care about is the noise. Which one is the most quiet after break in and wear? I hear the JUN is very quiet.
Old May 5, 2004 | 09:35 PM
tranzholik's Avatar
tranzholik
so does that mean the set up like ATS will not really benefit NA applications??
Old May 6, 2004 | 05:38 PM
Z1 Performance
Former Sponsor
an ATS twin for NA (stock displacement) is overkill yes. I have an ATS single disk on order for my own car.
BTW, the ATS's are single, twin or triple carbon disks, are larger than Tilton, and also include integrated lightweight flywheels as well
We carry them if anyone is interested, and also have 5 Fujitsubo cat backs in stock for the Z as well
Adam
Old May 17, 2004 | 10:33 AM
kopo's Avatar
kopo
bump
Old May 17, 2004 | 12:47 PM
shortcut3d's Avatar
shortcut3d
I keep asking this question too.
So what is the definitive answer, what is the quietest aftermarket light weight flywheel?
Z1 - please elaborate on the noise from the UR Flywheel.
sherm
Apr 11, 2020 05:21 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
