Nismo cams.....
Old May 9, 2004 | 09:58 PM
JDMxDrift's Avatar
JDMxDrift
Default Re: Re: Re: Re: Re: Re: Cam install complete....
Originally posted by Tim'sZ
Well, there are plenty of aftermarket parts for the Z out there now, not hard to make one a head turner. I have been working on mine for a little over a year and still not done. Here is recent picture...
Gosh, the brickyard is just beautiful... How much horsepower are you putting out with all that stuff on it?
Old May 10, 2004 | 05:52 AM
Tim'sZ's Avatar
Tim'sZ
Default Re: SES light...
Originally posted by can350z
None so far.... I did think about misfire and decided to throw in a set of NGK Iridium plugs to help out.... This is something you may want to do if not already.. I think the idle speed is important, perhaps set yours 50 rpm higher to see if that helps... If I get a light that will be my next move... Good luck...
R
Yea, my idle is set at 850 and has been doing fine. I will probably try the Iridium plug, where did you find the plugs and are you running a hotter or colder plug.
Old May 10, 2004 | 05:57 AM
Tim'sZ's Avatar
Tim'sZ
Default Re: Re: Re: Re: Re: Re: Re: Cam install complete....
We are right at 271 rwhp and 247 rwt, that equates to 330 hp at the crank and approximately 300 ft lbs of torque. I am sending my A/F readings to Tadashi to get ECU re-flashed, he feels there is still more hp out there just need to tweak it now.
Old May 10, 2004 | 06:56 AM
can350z's Avatar
can350z
Default Plugs...
clubplug.net is the way to go... Denso or NGK... your choice..
I went with stock heat range, no plans on going NOS or F/I
Good luck... Let us know how it turns out..
R
Old May 10, 2004 | 09:01 AM
Tim'sZ's Avatar
Tim'sZ
Default Re: Plugs...
R
Thanks for the info
Old May 10, 2004 | 09:42 AM
kzshin's Avatar
kzshin
Tim, what tire size you are using??
Old May 10, 2004 | 11:10 AM
Tim'sZ's Avatar
Tim'sZ
Fronts are 245/45/18's and rears are 275/40/18's
Old May 13, 2004 | 06:36 PM
can350z's Avatar
can350z
Default Done... for now.....
Way more power now.... Dyno in near future....
Now to figure out what's next.......
R
Old May 13, 2004 | 07:14 PM
Tim'sZ's Avatar
Tim'sZ
Man, your signature is starting to look alot like mine. Nice addition with the Crawford V5. You should dyno between 268 to 270 at the rear wheels maybe more. Keep us posted...
Old May 13, 2004 | 07:45 PM
350z4steve's Avatar
350z4steve
which cam nismo or jwt yields more RWHP in actuality ?
And which would work better with forced induction applications?
350z4steve's Avatar
350z4steve
Old May 13, 2004 | 09:30 PM
can350z's Avatar
can350z
I'm hoping with the Crawford flash Techno I can be 280+
My motor has been very strong right from new....
Still thinking about that Gruppe M intake too....
R
Old May 13, 2004 | 09:33 PM
can350z's Avatar
can350z
Default Cam differences....
They say that the peak HP between the two is only a few apart...
The Nismo cams make more power down low.. JWT S1's more midrange and upper end... JWT's are preferred for FI applications
My Nismo's are great!!!
Old May 14, 2004 | 03:46 AM
pimp1911's Avatar
pimp1911
Anybody have any thoughts on these Nismo Cams. There is a typo i believe in the description of the R-Tune Cam. It should say 262/256. What do you guys think about those Spec 1 and Spec 2 cams. Very aggressive. But not sure if they will fit in the stock head.
http://www.z1auto.com/prodmore.asp?m...ine&prodid=917
Old May 14, 2004 | 04:52 AM
Jeff@Performance's Avatar
Jeff@Performance
Performance Nissan
Just an update to an earlier question... our service dept has new lower pricing for my350z Forum members. The cam install went from $1200 to $960.
Old May 14, 2004 | 05:49 AM
Tim'sZ's Avatar
Tim'sZ
That is a bargain for the cam install since it is very extensive.
As far as the NISMO cams Vs JWT cams I know that either Jeff or Jason and Performance Nissan has tried both cams so they would be able to give you there opinion.
Old May 14, 2004 | 07:15 AM
Street Visionz, Inc.'s Avatar
so has anyone tried out those nismo spec 1 and 2 cams? Will they even fit in the stock head? Also have they officially been released to the US yet cuz I only see Z1 Auto carrying them.
Old May 14, 2004 | 09:07 AM
  #38
350z4steve's Avatar
350z4steve
wow dont tempt me..does this include bumping up the idle ?
jeff what did you dyno with the nismo verses the jwt? and which did you like better?
Old May 14, 2004 | 11:41 AM
  #39
pimp1911's Avatar
pimp1911
Times like this. I wish I lived in Cali. That is a real good price.
Old May 14, 2004 | 03:47 PM
  #40
287HP's Avatar
287HP
can350z,
Doesn't your engine scream a little louder now at 5200 rpm when your torque curve begins to climb again? I love watching my tach in forth gear right around 5200, and then feel the car begin to pick up speed again!
