Need help with Autometer A/F gauge!~
Old May 29, 2004 | 10:29 PM
E_Z_HOES's Avatar
E_Z_HOES
Exclamation Need help with Autometer A/F gauge!~
I am trying to throw in a autometer A/F gauge in my Z and going through hell trying to find which wire to connect it to. From what I see in the wiring diagram it says to tap into a yellow/black wire so I tried it ( there are 4 of them ). It doens't work. Brown wire seems to be the other source for the A/F gauge but I can't find any brown wire in my ECU wiring. The only brown wire that goes into the ECU that is brown is like 4 times the thickness of all the other wires and doubt that it's the wire I'm looking for. I have my car all rip apart now and need help ASAP....... Plese help me.
Old May 30, 2004 | 12:24 PM
dfw350z's Avatar
dfw350z
Default Anyone
I wish I could help but I am having the same problem with my G36c after installing my Vortech SC.
Old May 30, 2004 | 12:37 PM
Alberto's Avatar
Alberto
Cranky FI Owner
Honestly man the Autometer a/f guages are junk, they are not wideband's and are just for show. If your going through the trouble to install, at least use one that works.....
Old May 30, 2004 | 02:27 PM
dfw350z's Avatar
dfw350z
Default Re: Anyone
Nice comment, but do you know the wire to hook to so that we can give it a shot. Also: if they are junk then please recommend something better you are currently using that works.
Old May 30, 2004 | 08:05 PM
E_Z_HOES's Avatar
E_Z_HOES
I just got done installing the the A/F gauge. After hours of messin around and looking at serveral different layouts and instructions I found out a way to install the A/F gauge. It's simple as hell but everyone had to make it so damn complicated or have a comment that Autometer gauges sucked....
Old May 31, 2004 | 05:23 AM
dfw350z's Avatar
dfw350z
Default A/F Hookup
I am very interested in hooking up this exact gauge in my car. Could you please tell me the secret to installing this unit?
Old May 31, 2004 | 04:20 PM
E_Z_HOES's Avatar
E_Z_HOES
Right above the the cylinder #6 which is the last cylinder on the right as you are looking into the hood, there is a green connector. When you tuck back the connector ( it has 4 wires on it ) you will see a green wire. Tap the purple wire coming out from the A/F gauge into the green wire and you should be good to go. My A/F works fine. I found out that it was a green wire using a Multimeter. I heard something about our z's having different computers. Technoquare site stated that. I drive a Track model and couldne't find the brown wire, which was suppodedly the right wire to tap into so I got a Multimeter to find out which wire gave me a fluctuating signal when the car was running off the sensor. Good luck and let me know how things went.
bcoffee20
Nov 19, 2015 06:39 PM
FromGtoZ
Sep 20, 2015 03:41 PM
Calinismo350z
Sep 14, 2015 04:04 PM
