350z bored to 4.0
Old Jun 24, 2004 | 01:43 PM
Sins4u33's Avatar
Sins4u33
WTF....thats all im gunna say...and leave it at that... lol wtf....
Ben
Old Jun 24, 2004 | 02:05 PM
Conceyted's Avatar
Conceyted
hahah, poor guy....
Old Jun 24, 2004 | 02:09 PM
LBSOHK's Avatar
LBSOHK
holy $hit , buhahahaha , cant stop laughing..
Old Jun 24, 2004 | 02:24 PM
Z8M's Avatar
Z8M
ROFLMAO
Stroking your motor is pretty boring but does lead to detonation. I prefer to have my heads polished with longer stroke and an ample amount of lube. Then I usually set my forged shaft between big cam lobes and let it run until thermal and mechanical breakdown occur, or to make it simple just use your dipstick to check the oil.
Seriously
here's the answer to your question:
http://www.fordmuscle.com/archives/2...er/index.shtml
Old Jun 24, 2004 | 02:27 PM
zzzya's Avatar
zzzya
You would have to get a stroker kit and have some major internal work done to the engine. It is very expensive but if done properly, will yield great results. This is a great time to consider compression ratio for going FI or staying N/A as you simply choose which pistons you want to go with. If money is no option, then a stroked engine with 8.5:1 compression pistons and a ball bearing TT kit properly tuned would simply be incredible and still be very reliable. There is currently one stoker kit available right now from AEBS.
http://www.z1auto.com/prodmore.asp?m...ine&prodid=926
Old Jun 24, 2004 | 02:34 PM
Road Warrior's Avatar
Road Warrior
Originally posted by jeffw
I recommend getting your head polished the same time you're getting stroked for full effect. Believe it or not, female mechanics tend to be best at this skill. But you'll also want to get sleeved for protection. Also, the sleeve can reduce sensitivity to premature detonation.
Jeff
Old Jun 24, 2004 | 02:47 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
PoWeRtRiP - what are you basing your info off of?
Adam
Old Jun 24, 2004 | 03:04 PM
mpol99's Avatar
mpol99
You guys are killin' me
Old Jun 24, 2004 | 06:41 PM
S12 driver's Avatar
S12 driver
Would the VQ40DE block in the new Frontier bolt on to the VQ35DE heads? If they do, you can use that block and crank to make you engine 4.0L.
Old Jun 24, 2004 | 07:36 PM
Black03z's Avatar
Black03z
so when buying a stroker kit u are buying new block, pistons, con rods, and crank?
Old Jun 24, 2004 | 08:29 PM
ss350's Avatar
ss350
hahaha you guys a freakin halarious.. I have never laughed this hard on my computer.
Btw when you want to "stroke it out" (as you put it) just do what these guys said. They have great advice. Use lube, sleeve it, ect...
Old Jun 24, 2004 | 08:38 PM
Loco350Z's Avatar
Loco350Z
s12 driver- if your being serious(it can be hard to take people in this fourum seriously) that might be smething to look into. Very interesting.
Old Jun 24, 2004 | 09:01 PM
Spoon_sports808's Avatar
Spoon_sports808
poor guy ...
although i do not know how he doesnt catch on to these things fast enough ...
Old Jun 24, 2004 | 09:10 PM
elyliu's Avatar
elyliu
Black03z, i'll try to give you a serious answer....
stroking is like what some1 earlier said, increasing the displacement....but instead of increasing the bore of the cylinder, you are just moving the piston up and down more distance (increasing the HEIGHT of the cylinder, instead of the radius)....
I believe a new crank and connection rod is enough, I am not sure.... Don't need a new piston since it's same radius cylinder.....
Old Jun 25, 2004 | 03:42 AM
PoWeRtRiP's Avatar
PoWeRtRiP
mostly what ive heard from others that have rebuilt blocks, do you think that they can be bored more? i would doubt there is enough material there to seriously bore it out much.
Old Jun 25, 2004 | 04:01 AM
Speedracer's Avatar
Speedracer
Originally posted by Black03z
can someone explain stroking or give me a link. i tried to search
The rated displacement of an engine is related to the volume of all the combined cylinders. That, in turn, is related to the cross-sectional area of each cylinder multiplied by the length of the downward dislacement of the top of the piston from maximum compression to maximum expansion caused by the combution event within the cylinder. This downward displacement is the stroke. When you "stroke out" an engine, you alter the shape/size of the piston and/or connecting rod and/or crankshaft to allow for greater downward displacement. Along with increasing cylinder bore (diameter), this is one way of increasing engine displacement.
Old Jun 25, 2004 | 05:29 AM
genieman17's Avatar
genieman17
Technically all you need is a new crankshaft and new connecting rods, but if you've already got all that taken apart, there is no reason not to replace the pistons with better ones and all the other stuff thats in there tooo...
Old Jun 25, 2004 | 06:16 AM
  #38
sausage5000's Avatar
sausage5000
okay, seriously.
all that would be hella expensive. is it not true that maxima VQ30 or VG30 (i cant remember which) heads would raise compression enough to enhance your HP the N/A way, and be kinda cheap. junkyard to get the parts...
Old Jun 25, 2004 | 06:21 AM
  #39
PoWeRtRiP's Avatar
PoWeRtRiP
nismo offers an upgraded vq30 style head which would on a stock car raise the compression to 12:1. there are some serious differences between these head and the regular vq30 im sure someone will chime in and fill you in on the rest, i would not recommend simply putting a stock vq30 head in there and expecting the same results.
and to my knowledge noone has really tried these heads and gotten results other than the nismo race team.
Old Jun 25, 2004 | 06:43 AM
  #40
sausage5000
of course, it wouldnt be quite the same results as race heads, but from what i have heard, you still get 11:something out of maxima heads. ...isnt stock VQ35 something like 10:5:1?
