Could a TS Limited Reflash erase the timing advance I had Nissan do?
Old Aug 19, 2004 | 06:40 PM
done12many2's Avatar
done12many2
Default Could a TS Limited Reflash erase the timing advance I had Nissan do?
I just had my ECU reflashed with the "Limited" spec flash. All I had them do was raise the rev limiter, speed limiter, and fix the throttle. Could the reflash have erased the timing advance that I had my local Nissan service department adjust with the Consult II? The reason I asked is I lost about 5 to 6 HP from my dyno last week compared to today's (after the flash). I did not think about it while I was at the dyno, but the tuner said that I definitely lost a little bit of power.
Old Aug 20, 2004 | 02:58 AM
westpak's Avatar
westpak
SFZCC
My guess is that they reflah with a new program and probably with stock timing, just have them hook up the concult and check, are they charging you for that? ittakes like 5 minutes.
Old Aug 20, 2004 | 06:24 AM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
not really sure on your original question. But keep in mind that dynos can vary widely...even on the same day...same dyno. So plus or minus 5whp is probably just sampling error.
Old Aug 20, 2004 | 08:02 AM
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
That's what I was going to say (sampling error).
While it may only take 5 minutes to "hook it up" to the Consult II, I have been told that it take MUCH longer to actually "download" the program onto the ECU.
Old Aug 20, 2004 | 09:52 AM
westpak's Avatar
westpak
SFZCC
You don't have to download the entire program, they simply have to go to the screen that has the timing advance and raise it or lower it +-5 degrees, that is it. It only takes 5 minutes at the most.
liqalu04
Jan 2, 2022 12:58 PM
kyin
Oct 15, 2015 05:54 AM
nanotech
Oct 2, 2015 05:02 AM
TrboMike
North East
Sep 28, 2015 06:36 PM
Twiztids4
Tuning
Sep 10, 2015 04:02 PM
