Crawford Z
Old Aug 30, 2004 | 07:02 AM
Duflacci's Avatar
Duflacci
Default Crawford Z
Just got off the phone with Doug @ Crawford and ordered some Hi flo cats.....it was a pleasure dealing with Doug and I highly recommend Crawford, top quality parts and service.......
Old Aug 30, 2004 | 07:18 AM
lowrider's Avatar
lowrider
Ditto
Lou
Old Aug 30, 2004 | 07:19 AM
booger's Avatar
booger
You will like them...exhaust will sound civil , but still agressive......and best of all NO RASP...A little tuff to get on . The cat is up close to the header flang , makes it hard to get to the bolts
Old Aug 30, 2004 | 07:23 AM
Duflacci's Avatar
Duflacci
As long as its easier to install than the crawford headers
Old Aug 30, 2004 | 07:52 AM
Iezzi's Avatar
Iezzi
You must love those Crawford Z Headers! I want a set so bad!
Old Aug 30, 2004 | 01:20 PM
Z CRUZN's Avatar
Z CRUZN
Default CrawfordZ
Doug Stewart & his crew are are great bunch of fellas to work with, for sure! Service & quality is great........ Gettin' ready for another trip down there for some cams, polished engine front cover & the T/S ECU re-flash. Can't wait!!!
Old Aug 30, 2004 | 01:25 PM
Zmego1985's Avatar
Zmego1985
Default Re: CrawfordZ
Crawford rules i have all their products and i dynoed 255 hp without my reflash and im a auto.
Old Aug 30, 2004 | 01:39 PM
hungster's Avatar
hungster
do our cars loose that much hp from the flywheel to the wheels?
Old Aug 30, 2004 | 04:30 PM
PhoenixINX's Avatar
PhoenixINX
16 - 18%
Old Aug 30, 2004 | 08:48 PM
maserom's Avatar
maserom
Don't think it is quite that high. nice try. My dyno was at 261 hp
Old Aug 31, 2004 | 03:10 AM
Duflacci's Avatar
Duflacci
I have heard 17% loss.....but with F/I who cares....
Old Aug 31, 2004 | 04:27 AM
Alberto's Avatar
Alberto
Cranky FI Owner
What correction and smoothing factor?? When I was putting down 254 SAE corrected, that was 262 STD corrected. Then the smoothing at 0 can show a few more hp than the smoothing at 5....
Old Aug 31, 2004 | 04:36 AM
VandyZ's Avatar
VandyZ
I use SAE correction with a smoothing factor of 3.
Old Aug 31, 2004 | 05:23 AM
Alberto's Avatar
Alberto
Cranky FI Owner
I use SAE. Usually the smoothing at 5 though...what do you put down on the dyno, I think we have similar mods except I dont have the headers...
Old Aug 31, 2004 | 06:52 AM
Zmego1985's Avatar
Zmego1985
My car is not tuned my AF is in the 14s if i get back in the low 13s or high 12s i will have alot more power more then you im sure. Wait till im tuned and have my JWT cams in also!!!!!!!
Thanks Glen
Old Aug 31, 2004 | 10:28 AM
lowrider's Avatar
lowrider
Something I don't understand here. If the drive line components remain the same, whey should the drive line loss be a percentage of HP, as you modify? Why shouldn't it be a constant? What happens if I do things to make the car lose horsepower, is it still a percentage? I certaintly understand it being different between a 5AT and a 6MT. Someone explain please.
Thanks
Lou
Old Aug 31, 2004 | 09:54 PM
zrdude's Avatar
zrdude
Hey there--we met when I was out from CA checking out the shop. I went with the Crawford Package & TS reflash too, but I have pinging at 6200 now. I'm trying to work it out with my tuner now and am bringing to the dyno tomorrow to try and see what it going on. Kind of a bummer--haven't gotten anywhere near the gains I was hoping for so far. Could be the $hitty CA 91 oct. gas...who knows. I'm preparing a complete write-up with pics, dyno's etc. soon. Should be the most thorough write-up on the Crawford package to date.
What is the polished front engine cover? Do you have pics? I just had my stock engine cover cut to fit--looks okay but cuts partly through the V.6....
Old Sep 1, 2004 | 03:24 AM
zzzya's Avatar
zzzya
I would probably relate the pinging to both the 91 oct gas and the higher temps you see out in Cali. If I were you I would try to make it to Technosquare's shop and have them adjust the ECU. That is the best way to do it. Many have sent theirs back and forth trying to get things just right including myself. The polished front cover is the actual metal engine cover on the front of the engine. It looks very nice with the polished plenum on the car, but it takes a lot to have it installed so its best to do it with cams if you want to go that route. My camera is still shot or I would post a pic. mcduck posted some pics a while back when he had his installed.
Old Sep 1, 2004 | 04:18 AM
VandyZ's Avatar
VandyZ
Here are some pics for you. Crawford parts on an engine out of car where you can see everything.
Old Sep 1, 2004 | 09:51 AM
zzzya's Avatar
zzzya
That must be whosdaddy's?? Getting cams and a front cover?? Looks like a supercharger braket on the front.
