Airflow rates for Stock airbox???
Old Oct 5, 2004 | 03:16 AM
ZinMiami's Avatar
ZinMiami
Default Airflow rates for Stock airbox???
Does anyone have the rate of air flow for the stock airbox? Also, how it compares on average to an after market intake solution? Lastly, I would like to know the flow of the K&N drop-in versus others, ie. stock box and avg aftermarket.
Thanks in advance
Old Oct 5, 2004 | 06:33 AM
Q45tech's Avatar
Q45tech
Flow rates are how aftermarket confuses you into thinking a mod does anything.
The engine can only injest 214 ci/2......x rpm all divided by 1728 = 402 CFM @6500 rpm if it had 100% VE vs 280 CFM @4500 rpm.
By definition the torque peak rpm is the hight VE point [most air per cylinder gulp]. As the rpm goes above this point the restrictions from the intake valves and time for air to pass the valves starts a small but steady decline in efficiency.
By 6500 rpm the torque has fallen to 214 lb/ft/260 peak= 82% efficiency SO instead of ~~ 402 CFM the flow is 402 x 0.82=~~ 330 CFM @ 6500 rpm............at 6,000 rpm the efficiency might be 85-87%.
The correct way to measure the restriction of all the stuff in front of the throttle body is to tap a rubber line in front and read the pressure restriction from the atmosphere in inches of water with a MANOMETER. Typical HIGHEST readings are in the order of 11-13 " of water column [11/27.7= ~~0.397 psi negative or 0.4 x 6.8= 2.7% restriction to flow.
Air filter might be 1" water column and MAF ~~ 7".........the other 4" comes from air box and and air ducts from MAF to throttle body.
You can't do anything about 64% of the losses so you are playing with 1% [2-3 HP] that remains.
Other than the sound mods create there is little to be gained per $100 of expense!
http://www.bobistheoilguy.com/airfilter/airtest1.htm
Old Oct 5, 2004 | 09:22 AM
ZinMiami's Avatar
ZinMiami
Thanks! That was a great explanation. Makes sense why most intakes only make ~3HP or so.
Old Oct 5, 2004 | 10:03 AM
Strife350z's Avatar
Strife350z
great stuff... incredible explanation
Detailed Image
Cleaning & Detailing
Sep 28, 2015 03:03 AM
