Best place to buy Tomei cams???
Old Oct 10, 2004 | 10:43 AM
LOU's Avatar
LOU
Default Best place to buy Tomei cams???
Looking to get a set of cams. There are two people locally running JWT cams with their Vortech S/C. I was thinking about doing something a little different and try the Tomei 264 cams.
Also, can anyone explain the difference between the Nismo 262 , JWT 260 and Tomei 264?
As far as I know, the JWT perform better than the Nismo on the top end. If this is true, does that mean the Tomei 256 cams will perform better on the top end than the 264 and 268?
I am just trying to get an idea how the duration/lift effect whether you get a good idle cam, get better mid-range power or betrer top-end power.
Does anyone know the duration/lift on the stock cams?
Thanks!
Old Oct 10, 2004 | 10:44 AM
LOU's Avatar
LOU
Disregard the stock cams question. It is 238 In, 240 Exit.
Old Oct 10, 2004 | 12:40 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
Not sure about JWT but the NISMO's are a nice step up from stock but nothign too hairy
The Tomei 264's will walk them though in terms of mid range and top end power due to their increased lift. Tomei typically does a relatively mild duration and big lift as their signature to maing a broad powerband
This is a good article in leyman's terms about how different factors affect overall performance
http://www.streetracersonline.com/articles/camshafts/
Old Oct 10, 2004 | 01:41 PM
can350z's Avatar
can350z
Default Nismo lift same as Tomei 256 and 264.. 10.2mm
Only the Tomei 268's have more lift than Nismo's...
JWT's have more lift than Tomie 268's... 260 duration though..
I would say that Nismo's and 264's are comparable...
268's will have the much increased mid and top end.. with a loss of low end though...
I'm happy with my Nismo's.. nice broad powerband and good idle..
Old Oct 10, 2004 | 02:52 PM
Z1 Performance
Former Sponsor
LouZer - is this going on an NA car or a forced induction car?
Old Oct 10, 2004 | 03:44 PM
LOU's Avatar
LOU
This is for a car with a Vortech S/C
Thanks for the article
kyin
Oct 15, 2015 05:54 AM
KOF
Tuning
Sep 30, 2015 04:09 AM
