Manual tranny fluid & Nissan warranty
Old Oct 12, 2004 | 04:09 PM
crazysets's Avatar
crazysets
Default Manual tranny fluid & Nissan warranty
Hello,
If I replace the tranny fluid with anything other than the factory Nissan tranny fluid, will this void the warranty on a 6MT?
The manual states that replacing the tranny fluid on a A/T with anything other than genuine Nissan fluid will void warranty, but doesn't mention anything about MT's. Any solid advice?
-Patrick
Old Oct 12, 2004 | 04:57 PM
Jaki's Avatar
Jaki
If I remember correctly I read somewhere that the 6mt tranny fluid should not be changed until some really high miles (60k+ or was it 90k+). I think on the a/t they have to be changed after 30k.
Old Oct 12, 2004 | 05:06 PM
crazysets's Avatar
crazysets
Actually, I've been reading these threads and noticed that people are doing their first tranny fluid change anywhere from 3,000 - 6,000 miles. Just not sure if changing the MT fluid will void warranty.
While I'm at it, can anyone also recommend a good tranny fluid? I was leaning towards Amsoil as their products have gone into my other vehicle and I think they're great. I've been hearing a lot of Royal Purple and Redline. Any suggestions?
Old Oct 13, 2004 | 07:10 AM
Edogg218's Avatar
Edogg218
Redline made my Spec V's transmission livable, but I'm not sure what it will do for the Z. I'll probably try it soon...
Old Oct 13, 2004 | 07:14 AM
BigRich's Avatar
BigRich
Redline...I think 75w-90. MT-90 for the rear...which I think is basically the same fluid...
Old Oct 13, 2004 | 07:23 AM
VandyZ's Avatar
VandyZ
I used Redline Super Light Shockproof @ break in (1200 miles). No tranny issues . . .40K miles vin 0153. A couple others who have changed to the same dont have issues either. I know of 3 others with similar driving styles and stock fluid that have gotten or are getting new transmissions.
Not to say it is all in the fluid, but it does work. BTW, stock fluid looked like water .
Old Oct 13, 2004 | 09:14 PM
alininger2001's Avatar
alininger2001
I use redline 75w90, I will probably go to the pink stuff next time I change it. (pink stuff is redline lightweight shockproof oil)
Old Oct 14, 2004 | 02:28 PM
crazysets's Avatar
crazysets
The Redline Shockproof is exactly what I've been reading on other forums. But, I heard that this is a tranny oil designed for racing applications? Also, what would be the ideal Shockproof weight, 'Super Light' or 'Light Weight'? I noticed the Shockproof tranny oil doesn't have any weight numbers.
Old Oct 14, 2004 | 02:43 PM
KyleB's Avatar
KyleB
nissan doesn't have tranny fluid, so no.
Old Oct 14, 2004 | 03:43 PM
THX723's Avatar
THX723
The Genuine Nissan MTF is generally prefered. However, the stocker fluid just isn't heavy duty enough for above average use. For that, a pefrect (alledgedly) full synthetic substitute, the Shell Spirax S 75W90.
For more details ... check HERE
Old Oct 14, 2004 | 03:53 PM
G3po's Avatar
G3po
Default MT oil
I use Royal Purple Max 75w-90 , works like a champ.
Queiter and smoother.
Old Oct 17, 2004 | 01:23 AM
THX723's Avatar
THX723
Atland,
What's your take on the Redline and Royal Purple stuff?
Old Oct 17, 2004 | 11:11 AM
THX723's Avatar
THX723
No worries ... you have me sold. BUT ... where in the heck can I get some of this Spriax stuff in the States??? I even googled and no luck! Please advise!
Old Oct 22, 2004 | 01:50 PM
Gmike's Avatar
Gmike
Went with Redline at 600 miles - new trans at 12800...
Old Oct 22, 2004 | 01:58 PM
G3po's Avatar
G3po
Default redline
I doubt your Redline change exacerbated you trannies demise, it most likely prolonged it.
WRT Redline and Royal Purple , they both have been tested again and again on pro-race circuits. The reason they are not useually used in fleets is that they cost more (but you also get what you pay for) in this case.
lapham3
Oct 7, 2022 03:15 PM
sales@czp
Sep 23, 2019 03:30 PM
BOATS N HOES
Lighting
Oct 13, 2015 09:07 AM
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
