GL-5 in manual transmission okay?
Old Nov 8, 2004 | 04:27 PM
crazysets's Avatar
crazysets
Default GL-5 in manual transmission okay?
I was accidentally shipped the wrong tranny fluid. I thought I had ordered Amsoil Series 2000 75w90 (GL2 - GL5 compatibility), but was sent Amsoil's Severe Gear (specifically rated GL-5). Now, to my understanding, the 350Z is specifically rated for GL-4? I've read that GL-5 causes premature synchro wear? Also, I noticed that the Amsoil Severe Gear 75w90 is not even recommended on Amsoil's 'Application Guide'. What do you all think I should do with this stuff? Put the Severe Gear 75w90 in, or put it away and order the Series 2000 75w90?
Old Nov 9, 2004 | 12:24 PM
johnlotusboy's Avatar
johnlotusboy
Our cars use 75w85, any other oil will void the warranty.
The cars doesn't use 75w80 or 80w90.
75w85 is a special GL-4 for manual transmissions, only available from Nissan. I believe some of the Dodge trucks use it in their transmissions, and Dodge dealers also have it on the shelf.
Old Nov 10, 2004 | 05:55 AM
arizzee's Avatar
arizzee
Just to add to the confusion, the Nissan service manual dated May 2003, Revision Oct. 2003, states the following recommendations:
Genuine Nissan Manual Transmission Fluid (MTF) HQ Multi 75W-85 or API GL-4, Viscosity 75W-85 or 75W-90.
That's verbatim.
I do know that my other service manual (dated Dec 2002) stated only the 75W-85 API GL-4. When I went to the dealer and asked for the 350Z tranny oil, they handed me a bottle of Penzoil 75W-90, which I did not purchase.
For what it's worth, I switched to Amsoil Series 2000 75W-90. Although it did not cure the third gear grind (when cold), the tranny is so much quieter now.
I went systhetic in the diff also and it feels like I can break the tires loose much easier now.
Old Nov 10, 2004 | 09:47 AM
mwaller's Avatar
mwaller
I wouldn't use a GL-5 oil in the manual transmssion. GL-5 has a higher concentration of extreme-pressure additives, which can corrode the syncronizers. Stick with with a GL-4 unless you know for certain that your GL-5 is designed for compatiblity with yellow metals.
Mika
Old Nov 10, 2004 | 11:33 AM
G3po's Avatar
G3po
Default Synth in 6mt
Mika
For what it is worth I use Royal Purple Max 75W90 and it most definately is compatible with all yellow metal requirements.
I have used it fro 5k miles and it most definately resolved a 1st to second "crunch" under very rapid speed shifts with a rougue shifter. I used to crunch about 1 out of ~20 shifts before , since the change out , never had a crunch since.
The only downside noted so far is that for a few miles after a bone cold start, downshifting into 2nd takes more effort (the second grear sychro produces less useable friction when cold).
07ZEKE
Aug 23, 2021 09:15 PM
burglapfd
Dec 6, 2020 01:04 PM
MyZ2Slow
Mid-Atlantic Marketplace
Sep 9, 2015 10:17 PM
