Test Pipe SES Non-Fouler Fix... pics
Old 08-19-2009, 04:00 PM
  #141
derekinthez
derekinthez's Avatar
Default Do the 2003's need this fix?
Originally Posted by Blurr350z
Since installing my Labree test pipes, I threw an SES after about 50 miles. I didn't do the non-fouler trick at first because I thought there was a chance I wouldn't see the light (I have an '04, turns out it must be an '04.5 since I threw the SES).
Do the 03's need this fix? Has anyone run TP's on an 03 w/ or w/o the fix?
edit: research on this forum suggests the 03 does not need this fix. I went ahead and did it anyway, just to be safe. Stillen test pipes installed and no CEL so far. Also the sound is awesome after 3k rpm. Definately more responsive from 3k. No rasp or crappy sound.
Last edited by derekinthez; 08-21-2009 at 03:54 AM. Reason: answering own question
Old 08-28-2009, 10:40 AM
  #142
WillWork4Z
WillWork4Z's Avatar
cops arent going to pull you over for a rich smelling exhaust, so dont be so paranoid. Trust me, im a law enforcement officer, we could care less, at least in milwaukee....
Old 09-09-2009, 02:28 PM
  #143
johndoesdamage
johndoesdamage's Avatar
I have an 05 z 2 non foulers in each tp and still getting cel. I tried stuffing with brillo and still got cel. I wanna know is possible to do 3 non foulers per tp maybe drilling the second and third one or just drilling the third one out? Will 3 fit or is there not enough room down there? My brother was telling me I can solder like a resistor and capacitors to 02 sensors like he did on his jag and cel wont come on....has anyone done this? Ive seen some cars where they weld in jbend bars hows that work?
Old 09-10-2009, 02:22 PM
  #144
johndoesdamage
so I got some used 02 sensors and replaced mine everything works fine now I added the brillo to each stack of foulers.I realized you cant fit 3 foulers theres no room it hits the tranny oil pan.
Old 09-27-2009, 08:59 AM
  #145
boomfranco
boomfranco's Avatar
Old 09-28-2009, 04:43 AM
  #146
quakerroatmeal
quakerroatmeal's Avatar
Used 2 for each side on my 04.5 ..300+ miles and no SES. Just an awesome smell of fuel.
Old 10-27-2009, 04:51 AM
  #147
bonnie420
bonnie420's Avatar
ok here gos , i have a 03 base ,replaced motor with an 04 ,the 04 o2's would not plug in my harness so i took the ones out of the old motor and put them in the o4 , now car runs like crap and inside smells like gas bad. running on 3-4 cyl i would guess . i dont have 175.00 ea for new o2's what should i do .? im thinking about building o2 simulaters from radio shack parts list thats floating around the internet.my friend did the swap of the engines for me i paid him 1000.00 dollars for it it started than ran like **** and he said have a nice day than sold a extra rearend i got when i bought the motor for 3 hundy and never kicked me a dime . im going to have someone pick up the trany i got as well to mar oh as its on crags list for a 1000.00 its like a kick in the nuts nice friend .not im putting on my test pipes and goin to do the nofower thing but if my o2's r screwed up wont it still throw a coad??? thanks for your time
Old 10-27-2009, 01:43 PM
  #148
Hexxus
Hexxus's Avatar
That doesn't even sound like an 02 sensor problem.
Old 11-06-2009, 06:22 PM
  #149
winterdevilg35
winterdevilg35's Avatar
well heres my experience. i have an 03 G35 and i have all breather mods and FI testpipes with the non foulers installed by them. They worked good for a little while then i got the CEL. One of the testpipes (resonated) was rattling so i sent them back and they rebuilt them for me with new resonators. During that time i had my stock cats on and my CEL was no more. Put the Testpipes back on and once again a few hundred or less miles the light comes on. What i noticed is when i had the cats on they cleaned my O2 sensors from when they were black with the Test pipes. So to sum it all up: Before i put on the testpipes the sensors were clean. After i took them off and put on testpipes it took a couple hundred or less miles to get a CEL. Took off testpipes and sensors were black then put on cats. Took them off sensors were clean again and during that time no CEL. Put new testpipes back on and a lil while later CEL. Also after i dropped my transmission lately to replace my old one with a CD0009 I had to disconnect my O2 sensors and they were black like i anticipated then i cleaned them off with a rag at the shop and eventually put them back on and it was either that or that my battery was disconnected causing the ecu to reset. Either way the only way to fix it with my experience is get the simulators or something. Sharif from Forged Performance said that he can delete that CEL for good when i get my UTEC and tune from them. Thats my contribution.
Old 12-10-2009, 06:08 PM
  #150
Carter86
Carter86's Avatar
I have 04.5 and installed non-foulers on my megan resonated V2 TP. I just drove 120 miles and the check engine light came on. Im so confused
Old 12-10-2009, 06:22 PM
  #151
bad 350z
bad 350z's Avatar
i put the non foulers on my08 the cel came on about 250miles so i added a third one and same thing came on after 250 miles whats next...
Old 12-21-2009, 12:29 PM
  #152
Carter86
Carter86's Avatar
just pulled the code and i have bad MAF sensor. I just had a car accident few weeks ago and the bodyshop fixed my Z nice but it seems like the MAF sensor they ordered for me is bad. After I get that taken care of, we'll see if the O2 fouler is working or not.
Old 03-16-2010, 12:00 PM
  #153
johndoesdamage
So im running 2 non foulers on each test pipe and my cel never goes away it goes but always comes back after like 15 miles. I also added brillo and it still comes back. Do I need to add 3 nonfoulers or should I go to a shop and have them weld in a j bend pipe? I have a 2005 350z does it have wideband? I dont have money for a tune right now also so that option is gonna have to wait.
Old 03-17-2010, 04:22 AM
  #154
Hydrazine
MOTORDYNE-MY350Z SPONSOR
Hydrazine's Avatar
What is the code number and what year is your Z?
Old 03-17-2010, 01:02 PM
  #155
johndoesdamage
1273 and 1283 on occasion
2005
got the risers today but I only got 6 dont I need 8 for the gold plate in the middle?
Old 03-17-2010, 01:31 PM
  #156
Hydrazine
Hydrazine's Avatar
You only need 6 of the risers.
Also, the codes you have show a fault in the F/A ratio. Not cat efficiency.
You probably have an exhaust leak at the header/test pipe flange interface.
Tony
Old 03-17-2010, 01:43 PM
  #157
johndoesdamage
cool I always thought I had one bcuz I have a really intense whistle like a turbo when I release the gas and its more intense than videos of oter 350z with test pipes
Old 04-07-2010, 06:53 PM
  #158
dproto09
dproto09's Avatar
need alil help, just installed megan test pipe v2 with the extend thread already in the test pipe. have a 2004 base mfg 11/03. am i still suppose to installed the non fouler. please need alil help. of is it just better to buy the electric o2 simulator from http://www.o2simulator.com/ ?? im in nyc... thanks.. by the way my cel codes are P0037, P0430.
Old 04-30-2010, 10:59 AM
  #159
johndoesdamage
This is what my brother did to my car after 2 nonfoulers and brillo didnt work. No cel after like 450miles. http://mustangforums.com/forum/4-6l-...work-pics.html
Old 07-13-2010, 03:13 PM
  #160
AcidJake75
Living in 350Z
AcidJake75's Avatar
Thumbs up
failed my inspection - did this DIY and drove for 30 mins and went back...passed..
This was CAKE... cost me 9 bucks for the fix..
DONE and DONE!
Quick Reply: Test Pipe SES Non-Fouler Fix... pics
