Oil Change 101 - What you need
Old Jun 26, 2006 | 06:06 PM
  #41
drgon66's Avatar
drgon66
Ive been using 15w-50 Mobile 1 EP oil..is this ok, or should i go back to 10w-30?
  #42
drgon66's Avatar
drgon66
oh yea, I live in houston, and drive very frequently
Old Oct 4, 2006 | 04:33 AM
  #43
RBlover69's Avatar
RBlover69
yea i live in florida now i gues what W u should use will be helpfull im in florida now and i just put syn 10w30 with the mobi filter. Used to use 5w30 in NYC.
Old Oct 4, 2006 | 09:47 AM
  #44
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Go with 10W30
Old Oct 4, 2006 | 10:12 AM
  #45
SteveZ's Avatar
SteveZ
I also use mobil one syn 5w30 in CT, if I moved to someplace not a freezing hell 8 months a year I'd use 10w30 syn.
Old Nov 6, 2006 | 10:05 AM
  #46
mg350ZR's Avatar
mg350ZR
Default Cut a bigger opening in the cover/shield?
It seems like several people were able to drain oil and change oil filter through the opening in the plastic cover, without having to remove it. While this may work, it sounds like it could potentially get messy, especially when removing the old oil filter.
I built some ramps (stagered/stacked 2x8s) and got under the Z for the first time last night. It looks like the oil drain plug is fairly easy to get to without having to remove the plastic shield/cover. The oil filter is a little more difcult to access through the opening without making a mess.
I am thinking about cutting the plastic shield to make a bigger opening. This would allow me to change oil and filter without having to remove the cover every time. Has anyone tried this? Seems like it should work fine.
Old Nov 12, 2006 | 07:31 AM
  #47
joegengsta's Avatar
joegengsta
in all of my cars during the summer, i've always used 5w-30 in my regular cars or 0w-40 (in the race car). in the winter, i like a heavier oil like 10w-30 in my regular cars, the thicker oil stays on the metal components better after i've shut the car off for a while.
Old Nov 18, 2006 | 10:29 AM
  #48
Enron Exec's Avatar
Enron Exec
Where can i get those washers for the drain plug? Can i use 1 washer maybe 2 or 3 times?
Old Nov 18, 2006 | 11:05 AM
  #49
charlie_rdstr_Z's Avatar
charlie_rdstr_Z
I was burning oil for the first two changes with Mobil 1 Synthetic 10W30. My father is an Oil salesman and researches the market and tells me to use 5W30. It went against legitimate internet information but I gave it a shot. I am at my 4th oil change and no oil burning. My last change last week I was at 5,500 miles and I notice the oil was beginning to get thin and warmed up faster meaning it didn't keep my engine stable or cool. I just switched to Royal Purple and notice it being much smoother and takes longer to warm up. I will stick to RP from now on. Also I didn't remove the 14 bolt cover and did the change quickly.
Old Nov 21, 2006 | 12:54 PM
  #50
Steve-O Z33's Avatar
Steve-O Z33
I was burning about a quart every few weeks until I switched to Royal Purple 5W-30. Now, it stays full. They claim you can go 10,000+ with this stuff, but I don't trust it. I changed early this last time to dyno but I'm going to wait about 5k.
Old Nov 21, 2006 | 03:43 PM
  #51
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
sorry for the late response, but
performance nissan parts, and MAYBE but it's not worth it. they get paper thin when you reinstall the drain plug, and they're less than $0.50
Old Nov 22, 2006 | 06:50 AM
  #52
SteveZ's Avatar
SteveZ
It had better be OK, I have used 5W30 Mobil One for 31k miles - no issues, plus living in a cold climate (New England) I prefer it at least for Winter.
Old Nov 22, 2006 | 06:52 AM
  #53
SteveZ's Avatar
SteveZ
Yep, that's an easy one - yes use them again if you don't mind oil dripping around the bolt slowly, or no, splurge and get a bag of the things and don't drip on the garage floor
Old Nov 22, 2006 | 06:56 AM
  #54
SteveZ's Avatar
SteveZ
I just put a rag under the filter on top of the cover, let it catch any drips from removing the filter. I would not cut the cover.
Consider yourself lucky - my 2003 Z did not even come with an opening. I think it was something like 18 bolts to remove to change the oil...
Old Nov 28, 2006 | 08:49 PM
  #55
ZSpectrum's Avatar
ZSpectrum
If i'm not mistaken filling up the oil filter with oil before you installed it, would cause that bit off oil to completely bypass the filtration before it circulated through the engine. Have you ever looked in a bottle of oil. I've seen particles down there before, and i'm using mobil1 full synthetic.
Old Feb 25, 2007 | 09:08 AM
  #56
stiv's Avatar
stiv
If your Z is lowered and you prefer to do your own maintenance and don't wanna deal with jackstands, I recommend a set of Race Ramps. I just dicovered them.
They're light, durable and have a profile that lends itself well to just about any lowered sportscar.
They're a bit pricey (around $200) but they're well made and worth it for me since a few of my cars are pretty low.
Old Mar 7, 2007 | 02:22 PM
  #57
acmw's Avatar
acmw
Is 10w-40 good for the z? any one have pics of the underpanel and where the 14 bolts are located?
Old Mar 7, 2007 | 03:04 PM
  #58
SteveZ's Avatar
SteveZ
from the FSM:
SAE Viscosity Number
GASOLINE ENGINE OIL
SAE 5W-30 viscosity oil is preferred for all temperatures. SAE
10W-30 and 10W-40 viscosity oil may be used if the ambient
temperature is above -18°C(0°F)
So if it's not cold where u live, 5W-30 preferred for lower temp range.
other tidbits -
Oil pan drain plug:
: 34.3 N·m (3.5 kg-m, 25 ft-lb)
ENGINE OIL CAPACITY (APPROXIMATE)
Unit: (US qt, lmp qt)
Drain and refill
With oil filter change 4.7 (5, 4-1/8)
Without oil filter change 4.4 (4-5/8, 3-7/8)
Dry engine (Overhaul) 5.4 (5-3/4, 4-3/4)
keep in mind this based on '04, specs may have changed with the newer engine, but I doubt it.
The bolts are just all the 10mm ones you see under the car that hold on the big black hunk of plastic. If you don't have an access hole for the drain plug and filter, you have to remove the guard.
Old Mar 7, 2007 | 05:00 PM
  #59
shinkuu's Avatar
shinkuu
how many miles could one go on a KN Gold Oil Filter?
Old Mar 7, 2007 | 08:03 PM
  #60
SteveZ's Avatar
SteveZ
1 oil change, whatever your religion on that (~4k miles for me). Maybe a better filter, definitely beefy and have to love the nut stamped into the top, but other than using a good filter that may have higher flow rates and better filtration (maybe) you gain nothing in terms of reuse IMHO.
It's still the oil that limits usage, and I never reuse a filter for an oil change, so just be happy it's easy to replace and don't go cheap on your oil/filter changes.
I may get roasted for saying so, but I still think the OEM Nissan filter is very good, they at least have good quality and QC, I never see them leak out of the box or some other the other weird things I see with FRAM and others. Unless you have built out the engine, just get a good filter and change it 1:1 with the oil.
