DIY - Cooling fan assembly replacement from top
Old Aug 24, 2012 | 07:03 AM
stoffius's Avatar
stoffius
Default DIY - Cooling fan assembly replacement from top
2003 350Z
Sharing this since many posts state that it can only be pulled from the bottom. I've performed this twice since my first replacement assembly had to be warrantied so the second time I documented the process. Perform at your own vehicles risk and know that fluid will be spilled.
Tools needed:
1. Socket wrench & extension
2. 10mm, 12mm, & 14mm sockets
3. 10mm wrench
4. Flathead screwdriver
5. Pliars
6. Panel popper (not required)
7. Ziploc bags or empty storage cabinet
8. Bottle of 50/50 mix antifreeze
9. Disposable gloves
10. Tape
11. Cut milk carton or similar to catch coolant
12. Oil drain pan or similar (spilling coolant is inevitable)
Instructions
1. Disconnect battery
2. Remove bolts from strut bar on drivers side and the clips attached to it (14mm)
3. Lift strut bar an inch to get access to plastic engine cover with wrench
4. Remove engine cover (10mm)
5. Disconnect MAF sensor harness, loosen intake duct, and then remove intake airbox (12mm)
6. Remove bolt from A/C bracket underneath intake airbox and remove bracket (10mm)
7. Removed plastic clip holding down A/C line (white)
8. Remove bolt holding down coolant overflow tank (10mm) and disconnect the rubber hose at the radiator cap. Remove from engine bay. Keep end of hose elevated to prevent spillage
9. Place rag underneath radiator cap nipple to catch any overrun
10. Remove two bolts at top of fan assembly (10mm)
11. Jack car up on front passenger side, support with jack stand, and remove plastic shroud to gain access to fan assembly wire harness (10mm)
12. Disconnect wire harnesses and push aside so they’re not directly underneath coolant hose
13. Cover pulleys with a rag and have another rag on hand
14. Disconnect upper radiator hose from radiator and immediately stuff radiator with rag
15. Dump the fluid in the hose into the milk carton and then tape-off, out of the way, to the strut bar
16. Place milk carton underneath radiator and remove rag. Let drain
17. Now the fun part, removing the radiator. It may take some wiggling, but it will come out. Begin by pulling it straight up and pay attention to what it hits.
18. For a little extra room, remove the coolant overflow bracket held in place with 2x 10mm bolts. You won’t have much room to get a decent amount of torque or revolutions, but stop what you’re doing and take the time to remove it if you cannot manage to get the fan assembly out.
19. Once you have it out, LOOK AT ALL THE ROOM!
20. Consider replacing your belts and/or that bad pulley you’ve been putting off. Check the grounds and wire harnesses.
21. Reinstall in reverse order
22. Once everything is put back together and the car level on the ground, open the coolant bleeder valve located directly in front of firewall beside the battery.
23. Fill radiator at the cap and bleed the air out.
24. Voila! You’re done.
Notes:
1. I prefer to use the storage cabinet bin to store small parts removed placing them in the top left corner in order of removal going side to side. You can use Ziploc bags as well. Just make sure you maintain some form of order so you know the order in which they go back in.
2. Before performing this DIY, consider replacing your belts while you have the extra room. If you have a leak somewhere, add some UV dye and drive for 20 minutes before working on the car. The extra room with the fan assembly removed will allow you a better chance of pin-pointing that leak.
3. Print these directions out
4. I assume no liability and cannot guarantee this will work for your car. I have a 2003 so there you go.
Old Aug 26, 2012 | 07:48 PM
F2CMaDMaXX's Avatar
F2CMaDMaXX
Looks good to me, thanks for posting this up
Old Sep 9, 2012 | 02:26 PM
jtbinvalrico's Avatar
jtbinvalrico
Great write-up. I just acquired a 2005 350Z 6MT.......and it overheated on day two. Diagnosed the failure at the radiator fans. I'm assuming that one of the fans failed some time ago, and the second one just went out, leaving me with an overheated car. Makes me wonder how many others are limping along on one fan.
I installed my new fan assembly exactly as you did. I read some other write-ups which suggested everything from draining the radiator to removing the front bumper. Looking at it, it just didn't seem that all that trouble should be necessary.
Let me add this: The two wiring connections can be accessed from up top (disconnect is harder than the reconnect)......but I scraped my arms up a bit in the process.
Also, I'd recommend cutting a piece of cardboard to fit over the inside face of the radiator to protect it from any dings to the cooling fins while lowering in the fan assembly.
I came here to write it up, but I see you've covered it. Thanks.
Old Sep 9, 2012 | 07:59 PM
Smokey916's Avatar
Smokey916
Thanks for the write up! just changed my shroud and this helped a lot!
Old Jan 21, 2013 | 06:52 PM
eZg's Avatar
eZg
Did you modify the stock can shroud or go after market? If so which one and why?
Thanks.
George
Old Aug 8, 2014 | 11:47 AM
LesaZ's Avatar
LesaZ
Default Diving in
Hoping someone will respond to this old thread.
I got the estimate from a good mechanic to replace my non-functioning radiator cooling fans. Over $300 for the Nissan parts, $200 in labor. Yikes! It's just a fan (2) on the outside of the engine. C'mon! Anyway I'm diving in to do it myself and save $400. The DIY post in this thread will be my guide. Bless you!
While this is probably at the limits of my automotive DIY skills, I think I can do it. I certainly hope so! Any new advice to tackle this? Any recommended brand for that replacement unit?
Old Jul 28, 2015 | 01:26 PM
kno's Avatar
kno
Any write ups for an hr engine? Mods help!!
The radiator seems to be attached to the a/c condenser.
Old Jul 28, 2015 | 02:51 PM
kno's Avatar
kno
These are the two pipes I'm talking about.
this is for an hr engine
Old Jul 29, 2015 | 05:05 AM
eZg's Avatar
eZg
Isn't that inner most AC line the one OP unbolts in pic 4 (step number 6) ??
good luck
Old Aug 5, 2015 | 01:45 PM
wlewis53's Avatar
wlewis53
Do you really need to remove the radiator to replace the fans and the shroud? Looking at KNO picture it looks like the fans and shroud are removed and the radiator is still in the car.
Old Aug 5, 2015 | 01:55 PM
eZg's Avatar
eZg
/\/\ radiator can stay in place.
Been working on mine and almost done (Not an HR tho)
Old Aug 5, 2015 | 04:50 PM
kno's Avatar
kno
Ahh. I figured it out that same day but forgot to take a picture.in the picture I posted there are 2 radiators stuck together. one which is located towards the front of the car and that's connected to the a/c lines. the other is the one that carries the coolant which is the one located close sts to the engine. They are both connected by two 10 mm bolts located on the top front of the a/c radiator. I couldn't see it before because otherwise the plastic frame structure was covering it. Remove those 2 bolts and it will separate both radiators.
I hope this post is of help for those whom are stuck like I was.
Old Aug 5, 2015 | 04:52 PM
kno's Avatar
kno
My radiator needed to be replaces but you do not need to remove the radiator to replace the fans.
Old Aug 5, 2015 | 05:01 PM
nizmo_0385's Avatar
nizmo_0385
Great job kno. And thanks for the info for future.
Old Aug 8, 2015 | 11:16 PM
HRMoneyPit's Avatar
HRMoneyPit
Bumping this cause why did you need to take off the engine cover? Going to he doing this install once my new hoes clamps come in
Old Sep 8, 2015 | 06:13 AM
hardwood66's Avatar
hardwood66
FYI - you need to remove the engine cover to be able to pull the fan assembly out - need the extra 1 inch clearance that you get when you remove the cover.
Old Sep 8, 2015 | 06:24 AM
HRMoneyPit's Avatar
HRMoneyPit
I did my radiator and didn't touch the strut bar or engine cover. I have an HR though
Old Oct 14, 2016 | 09:14 PM
n_den's Avatar
n_den
just wanted to say thanks!, this worked out well, only thing i didn't do was the strut bar step, everything else was dead on. have a 05.
Old Oct 19, 2016 | 11:27 AM
CK_32's Avatar
CK_32
Anyone have a fan unit they wanna gimme they aren't using?
My unit cracked fans are great just the bracket and structure needs replacing.
I'll take donations and help someone clean up their garage parts bin
Old Dec 9, 2016 | 05:58 PM
dboyzalter's Avatar
dboyzalter
6 inch cawk is my fave!
I have one too bad you live on the other side of the country. How do you disconnect those AC lines? I couldn't figure them out and just cut them in half...
