DIY belts replacement without special tool
Old Nov 5, 2017 | 10:04 AM
Xsellr8's Avatar
Xsellr8
Default DIY belts replacement without special tool
Hello everyone. Here is a video I made on replacing the drive belts. I really wish these cars had a spring tensioner, but my method works pretty well. Check it out Shown on a G35, but should be the same
Old Nov 6, 2017 | 08:48 AM
JMII's Avatar
JMII
Thumbs up
Nice video... good job getting the camera into those tight spaces to show what needs to be done One correction: that is not a water pump, its just an idle pulley which can be removed as detailed here.
My AC belt finally snapped at 71K so I replaced it this weekend. I forget to count the turns and just used the twist method to determine the tension. I ran the car for 2 mins while still on the jack stands and got no squealing so I must have done it correctly. I then gave the tension screw 1 extra turn since FSM says to ensure the crank turns a few times before confirming the final proper tension.
Honestly the hardest part of this job is getting the car in the air and undertray off as lots of 10mm bolts/screws have to come out. After that it's a piece of cake. The only challenge is limited working space between the fans and engine block.
Old Feb 3, 2018 | 04:52 AM
Sean Wilson's Avatar
Sean Wilson
Mine are hella cracked. Thanks
Old May 12, 2018 | 03:55 PM
msk59's Avatar
msk59
5 Year Member
thank You. Very well demonstrated. Learned something new. This is HOW To videos should be.
