Engine Swaps For all your engine swap experiences, ideas, questions, & more..
G35 engine into 350z
Old Nov 9, 2015 | 03:11 PM
20350z03's Avatar
20350z03
Default G35 engine into 350z
So my engine blew and now I'm seeking a replacement. For some reason 350z engines are more expensive than g35 engines particularly the awd g35. I've done my research and I've come to the conclusion that any non rev up rwd engine will bolt into the z using my old engine mounts and harness, plenum etc. If I happen to get an automatic block I can just remove some part on the crankshaft and the manual trans will slip on no problem. Can anyone verify this information?? Also I had the question about the lower power ratings for the g35 and from research learned that the reason for this is more aggressive tuning on the 350z but the block and head parts are all the same on every non rev up block.
Sorry for my rambling..
Will an awd non rev up g35 engine work on 03 350z?
Are all rwd/awd vq35de internally created equal?
Thanks for for any input.. im trying to get my z back on the road but I dint want to buy the wrong **** trying to get a cheap, low mileage engine with a warranty..
Old Nov 9, 2015 | 04:09 PM
travlee's Avatar
travlee
Master
have you checked into the cost of rebuilding yours?
Old Nov 9, 2015 | 04:10 PM
travlee's Avatar
travlee
Master
if close to houston call IPP
Old Nov 9, 2015 | 06:34 PM
Conway_160's Avatar
Conway_160
I had an automatic 350z motor in my G35 for about 150 miles until it blew up... not a bad motor a bad f/I tune.
Old Mar 19, 2016 | 11:20 PM
pettyboy69's Avatar
pettyboy69
I'm curious about what you have to change on a g35x engine to make it work in a 350z?
DaytonaBlueZ33
Oct 28, 2015 03:22 PM
bangbang001
Wheels Tires
Oct 24, 2015 05:03 AM
navtool.com
Oct 22, 2015 07:13 PM
navtool.com
Oct 22, 2015 07:05 PM
4ngryToasters
Oct 14, 2015 12:38 PM
