Engine Swaps For all your engine swap experiences, ideas, questions, & more..
G35 / 350Z LS3 Swap, Best DBW Accelerator Pedal
Old May 25, 2017 | 05:21 PM
terminal's Avatar
terminal
Default G35 / 350Z LS3 Swap, Best DBW Accelerator Pedal
What would be the best Drive,By Wire Accelerator Pedal to use on a
G35 coupe /350Z LS3 / 6L80 Swap.
I had a 2013 Silverado pedal but it can't fit properly and it's a composite
pedal so can't cut and weld it.
What did others on here use for the best fit?
Also has anyone gotten the A/C to work?
Old May 29, 2017 | 06:06 PM
terminal's Avatar
terminal
I guess no-one has done the swap on here, to be able to answer the question??
Old Jun 9, 2017 | 06:14 AM
AKS14's Avatar
AKS14
I've used a newer Camaro pedal and mated it to the factory 350 bracket and it worked fine.
Old Jun 18, 2017 | 08:11 PM
mkiv20vt's Avatar
mkiv20vt
I took the Escalade Pedal assembly and cut it in half then re-welded to fit where the stock pedal went. Pretty straightforward.
Old Jun 19, 2017 | 03:48 AM
terminal's Avatar
terminal
Thanks for the replies, I took a 2007 impala pedal, cut off the pedal and re-welded the G35 pedal to it, looks stock now.
Old Jun 26, 2017 | 01:00 PM
jksstar's Avatar
jksstar
I used Drive by cable, not a fan of the DBW stuff
But glad you got it!
Old Jun 26, 2017 | 04:09 PM
jonnyidfw's Avatar
jonnyidfw
^^^^ I agree with You on the Drive-By-Cable Preference, but I'm running a LS2 in My 350Z & I would love to have a DBC setup instead of the DBW!! How is this done?
Thanks in Advance for Any info!
Old Jun 27, 2017 | 03:44 AM
jksstar's Avatar
jksstar
I'm not sure if you would need a new harness or if they make adapters (sure they have adapters by now) . But they make a DBC tb that fits a ls2 intake , then a cable ,tune and roll!
