Engine Swaps For all your engine swap experiences, ideas, questions, & more..
My 2jz swap
Old Dec 7, 2019 | 02:41 AM
  #201
chase z's Avatar
chase z
Default .
Update.
so the car started smoking on decel after a pull a few months ago and slowly it became worse and worse took the turbo off trubo seals where shot and the Center housing of the trubo was scored really bad tryed to rebuild it and it didnt help one bit. I'm currently out of the country for a year but when I get back I'm getting a turbo smart turbo oil regulator and a pt 7275 turbo. I'm hoping its actually makes 1k.
Old Mar 9, 2020 | 01:35 AM
  #202
TomeiExpremeTI's Avatar
TomeiExpremeTI
Originally Posted by chase z
Update. Smoking
Sorry if its already been asked but I legit made an account just to ask, what do you think is a good budget to have to start something like this but with mostly off the shelf stuff (I am **** at welding evidently even tho my father is a welder)
Old Mar 9, 2020 | 06:58 AM
  #203
bealljk's Avatar
bealljk
Look up Reagan's 1.5jz swap thread too...
Old Apr 4, 2020 | 07:13 PM
  #204
chase z's Avatar
chase z
depends on how far u want to go with the engine. But exhaust will probably still have to be custom.
loj is working on a 2j swap kit and if its anything like there ls swap kit it would definitely be worth the wait there stuff comes with everything.
Old Apr 5, 2020 | 09:45 AM
  #205
bealljk's Avatar
bealljk
Any updates on the car Chase? still out of the country?
Old Apr 12, 2020 | 05:34 PM
  #206
chase z's Avatar
chase z
yes I got back about a month ago now. Decided to just get a new Center cartridge for the bw369sxe. I also got the trubo smart turbo oil pressure ragalator. I installed all of that and drove it around about 80ish miles over the last few weekends on pump gas at 14psi. Feels pretty strong but I have e50 in the tank now and have it turned up to 18.5 psi letting the autotune clean up the rich under boost cells . Once I have over e60 in the tank I will slowly trun it up all the way to high 20s low 30s.
Old Apr 28, 2020 | 05:45 PM
  #207
chase z's Avatar
chase z
Some pics and a idling video with the new trubo. I will try and get a better video of a fly by or somthing soon
Old May 1, 2020 | 05:56 PM
  #208
chase z's Avatar
chase z
Me and my wife took the car to its soon to be new home coming this fall
Old May 3, 2020 | 08:39 AM
  #209
chase z's Avatar
chase z
I was feeling alot of movement in the transmission so I decided to ad some 94a urethane to the oem tran mount bushing
Old May 9, 2020 | 10:52 AM
  #210
chase z's Avatar
chase z
Just a quick 1st and 2ed gear pull definitely feel fast and a little sketchy but the video doesn't make it seem fast at all
Old May 9, 2020 | 11:43 AM
  #211
bealljk's Avatar
bealljk
You know how they say the video camera adds 15lbs ... the video camera takes off XYZ ft/s^2 acceleration ...
looks good/sounds good - happy to see it running!
Old May 9, 2020 | 12:25 PM
  #212
chase z's Avatar
chase z
So true well here is a out of the car pull aswell it
Old May 13, 2020 | 09:00 AM
  #213
chase z's Avatar
chase z
I got a to good to pass up deal on a older smithy mill/ lathe combo. A few little parts have to be ordered, then we will see what I can make!
Old Jan 6, 2021 | 08:31 AM
  #214
chase z's Avatar
chase z
I haven't posted any updates in quite awhile. Moved to a new house with a better separate shop layout and collected a few parts for a updated setup, bw476sxe trubo, oem radiator replacement with factory radiator support, oem ac components and moving the motor back about 3.5 to 4 inches so i can fit the oem ac / coolant components.
Old Apr 27, 2021 | 03:22 PM
  #215
chase z's Avatar
chase z
Old Jun 26, 2021 | 05:27 AM
  #216
chase z's Avatar
chase z
Old Sep 6, 2021 | 01:27 PM
  #217
chase z's Avatar
chase z
Old Sep 13, 2021 | 03:35 PM
  #218
chase z's Avatar
chase z
Old Aug 29, 2022 | 05:00 AM
  #219
chase z's Avatar
chase z
Old Oct 28, 2023 | 03:45 PM
  #220
chase z's Avatar
chase z
Some new beadlocks , 5in intake and some custom spacers to move the rad forward
