Engine Swaps For all your engine swap experiences, ideas, questions, & more..
Fuel lines Question
Old Aug 6, 2017 | 10:32 PM
rob2496's Avatar
rob2496
Default Fuel lines Question
Alright so I'm starting my 2JZ build, I havent found anything relevant to this which is why I'm asking so don't "flame" me I'm just hear to learn like everyone else. So I plan on using a Walbro 255 in-tank fuel pump and my question is considering my modest power goals of 500hp would I need a in-line fuel pump/fuel filter?
Old Aug 6, 2017 | 11:12 PM
SAMzG35's Avatar
SAMzG35
are you using stock basket? If so, isn't the filter built into that?
terrasmak's Avatar
I would suggest a -6 fuel line to and from the motor.
No idea if the pump will support your needs
Old Aug 6, 2017 | 11:21 PM
rob2496's Avatar
rob2496
The filter is attached to the bottom of the walbro fuel pump not the basket itself but I've seen plenty of builds using in-line pumps/filters on top of their in-tank pumps/filters but all of these builds have been 800hp+. I specifically seen a build using two AEM in-line pumps running to a in-line filter but then again this was probably a 1000hp build which I'm not going for.
