Engine Swaps For all your engine swap experiences, ideas, questions, & more..
engine block serial numbers vs chassis VIN#
Old Oct 4, 2017 | 07:01 PM
turbotommy350's Avatar
turbotommy350
Default engine block serial numbers vs chassis VIN#
Howdy,can you tell if the engine that is in your car is the one that came with it from the factory by the serial number on the block?
I ask this because my 350Z only has 76K on it and it died I would like to find out if it is the original from the factory or if it was swapped for a bunk motor.
Attached Thumbnails engine block serial numbers vs chassis VIN#-z2.jpg   engine block serial numbers vs chassis VIN#-z3.jpg   engine block serial numbers vs chassis VIN#-z1.jpg   engine block serial numbers vs chassis VIN#-z4.jpg   engine block serial numbers vs chassis VIN#-z5.jpg
