Engine Swaps For all your engine swap experiences, ideas, questions, & more..
04 DE won't start after engine swap
Old Jul 16, 2018 | 10:11 AM
z33cole's Avatar
z33cole
Default 04 DE won't start after engine swap
**Before I explain my situation let me say that I have searched the forums constantly for weeks, and while I have found useful information I haven't solved my current issue.
I have an 04 350z 6 speed and about 6 months ago the engine went. I swapped in a vq35de non-revup out of a g35 Coupe automatic and just swapped over my clutch and flywheel onto the new-to-me engine in place of the torque converter. Still using my original ECU and harness. Once everything was back together the car would crank and crank but not start and run. I dropped the crank sensor and it started and ran, but very poorly. I assumed the flywheel was positioned wrong so I dropped the transmission and sure enough it was. So I lined it up correctly with the dial pin on the crank and put it back together. It still wouldn't start and run, so I dropped the crank sensor again and it fired right up. It ran and idled smooth. I don't see how it could be the flywheel again since I aligned it correctly this time, but it won't run with the crank sensor installed at all. Already replaced both cam sensors and crank sensor, and still nothing. Kind of at a loss here, if anyone has any info to help me it would be greatly appreciated, thanks.
Old Sep 30, 2018 | 01:05 PM
sherm3721's Avatar
sherm3721
I am in the same boat. Put a RevUp from an '06 G35 into an '04 350z. No spark on my end.
Old Aug 17, 2019 | 04:50 PM
Taylor009's Avatar
Taylor009
Default Security system making it trip
Originally Posted by z33cole
Is your security system tripping or is you navigating system screen coming up and turning on ?
rrrrr
Old Aug 17, 2019 | 04:53 PM
Taylor009's Avatar
Taylor009
Is your security system tripping or is you navigating system screen coming up and turning on ? Because when I working on the head unit of a auto g35 05 and disconnect it it wouldn't turn on it would only crank until plugged back in
z33cole
Dec 9, 2019 05:07 PM
350zlaboy
May 30, 2014 06:38 AM
konrad
Mar 12, 2011 04:58 PM
BristishZ
Jun 9, 2010 04:15 PM
turboex
May 26, 2005 11:12 AM
