IPP Engine packages at GREAT Prices, 1 yr warranty, & NEW Lower Core Charges!!
What if i want this:
CP pistons 8.5:1 CR
Eagle Rods
ARP Rod Bolts
ARP Head Studs
ARP Main studs
Block inspected and cleaned
Block redecked
Block Bored and Honed using a Torque Plate
Rotating assembly balanced to 50%
Crank magnafluxed and the journals micro-polished
New Moly coated race Rod and Main bearings installed
Block assembled
CP pistons 8.5:1 CR
Eagle Rods
ARP Rod Bolts
ARP Head Studs
ARP Main studs
Block redecked
Block assembled
Vendor - Former Vendor
Front page deals:
For those of you who do not know me I have been racing and building Nissan's and Infiniti's for over 12 years now. I owned and built one of the fastest Nissan 300zx street cars in 1999 that held the 1/4 record until just a few years ago. The machine shop that does the machining of the engines has done some of the highest HP VG30DETT and VQ35 motors in the nation.
Because of the Volume of motors I do I have some of the best pricing on motor builds around. I also have multiple cores available(Including Rev-Ups) so I have a turn around time usually 2-3 weeks from time of order.
NEW: Lowered core charges!!!
That being said I have several engine packages that are sure to fit your budget and goals. Here is what I have to offer(parts in italics are upgraded from previous stage):
Short Block Packages
Stage 1 Short Block Package:
Wiseco Pistons .020 over
Eagle Rods
ARP Rod Bolts
Block redecked
Block assembled
This package runs only $2600 and can be purchased or get to get more details click Here
Stage 2 Short Block Package:
CP Pistons .020 over or Arias Extreme .020 over
Pauter Rods
ARP Rod Bolts
Block redecked
Block assembled
This package runs only $3550 and can be purchased or get to get more details click Here
Stage 3 Short Block Package:
CP Pistons or Arias Extreme .020 over
Pauter Rods
ARP Rod Bolts
ARP Main Studs
Darton Mid Sleeves installed on CNC machine
Block redecked
Block assembled
This package runs only $6050 and can be purchased or get to get more details click Here
Head Packages
Stage 1 Head Package:
Heads inspected and cleaned
Heads redecked
Ported exhaust and intake runners
3 angle valve job
New OEM Valve stem seals installed
Valve Stem Heights set
Cold Clearance set for stock cams
Heads assembled
This package runs only $1500 and can be purchased or get to get more details click Here
Stage 2 Head Package:
JWT S1, S2, C2 or "S7 Revup" Upgraded Cams
JWT Heavy Duty Valve Springs
Heads redecked
5 angle radius valve job
Heads assembled
This package runs only $2750 and can be purchased or get to get more details click Here
Stage 3 Head Package:
Ferrea Oversize Intake and Exhaust Valves
Ferrea Heavy Duty Valve Springs
Ferrea Titanium Retainers
Ferrea Valve Spring Locators
Ferrea Valve Locks
Heads redecked
Heads assembled
This package runs only $4450 and can be purchased or get to get more details click Here
Stage 4 Head Package:
Tomei Upgraded Cams(Non-RevUp Only)
Ferrea Valve Locks
Heads redecked
Extreme Ported exhaust and intake runners
Bowl Work Done
Heads assembled
This package runs only $4700 and can be purchased or get to get more details click Here
Long Block Packages
Stage 1 Long Block Package:
Eagle Rods
ARP Rod Bolts
Block redecked
Block assembled
New OEM Head Gaskets
Heads redecked
3 angle valve job
Heads assembled
New OEM Rev-up Oil Pump
This package runs only $4400 and can be purchased or get to get more details click Here
Stage 2 Long Block Package:
Eagle Rods
ARP Rod Bolts
Block redecked
Block assembled
Heads redecked
5 angle radius cut valve job
Heads assembled
This package runs only $5650 and can be purchased or get to get more details click Here
Stage 3 Long Block Package:
Pauter Rods
ARP Rod Bolts
Block redecked
Block assembled
Heads redecked
Heads assembled
This package runs only $6600 and can be purchased or get to get more details click Here
Stage 4 Long Block Package:
Pauter Rods
ARP Rod Bolts
ARP Main Studs
ARP L19 Head Studs
Block redecked
Block assembled
Cometic Head Gaskets(can be upgraded to HKS)
Heads redecked
Bowl Work Done
Tomei Upgraded Cams(Non-RevUp)
Ferrea Valve Locks
Heads assembled
This package runs only $11,499 and can be purchased or get to get more details click Here
Of course these are just the packages I have put together. Any package can be added to or subtracted from to meet and goals or parts your heart desires. I have several cores in stock so waiting time is usually only 2-3 weeks. Also full assembly and disassembly of the timing components can be done for added cost. Contact me for details.
You Rev-up guys don't fear. I have purchased a few RevUp cores so I can also have them done for you guys
Feel free to call me, email me, or IM me at anytime to discuss your goals and needs.
Short Block Packages Stage 1 Short Block Package:
Eagle Rods
ARP Rod Bolts
Block redecked
Block assembled
Pauter Rods
ARP Rod Bolts
Block redecked
Block assembled
Pauter Rods
ARP Rod Bolts
ARP Main Studs
Block redecked
Block assembled
Head PackagesStage 1 Head Package:
Heads redecked
3 angle valve job
Heads assembled
Heads redecked
Heads assembled
Ferrea Valve Locks
Heads redecked
Heads assembled
Ferrea Valve Locks
Heads redecked
Bowl Work Done
Heads assembled
Long Block Packages Stage 1 Long Block Package:
Eagle Rods
ARP Rod Bolts
Block redecked
Block assembled
Heads redecked
3 angle valve job
Heads assembled
Eagle Rods
ARP Rod Bolts
Block redecked
Block assembled
Heads redecked
Heads assembled
Pauter Rods
ARP Rod Bolts
Block redecked
Block assembled
Heads redecked
Heads assembled
Pauter Rods
ARP Rod Bolts
ARP Main Studs
ARP L19 Head Studs
Block redecked
Block assembled
Heads redecked
Bowl Work Done
Ferrea Valve Locks
Heads assembled
quote for this please.
Arias Extreme 9:1CR .020 over
Eagle Rods
ARP Rod Bolts
ARP Main Studs
ARP L19 Head Studs
Block redecked
Block assembled
HKS Headgaskets
Heads redecked
3 angle valve job
Heads assembled
Eagle Rods
ARP Rod Bolts
ARP Main Studs
ARP L19 Head Studs
Block redecked
Block assembled
HKS Headgaskets
Heads redecked
3 angle valve job
Heads assembled
