Engine Intakes, Exhausts, Clutches, Turbos, etc...
sleeved block, stage IV heads-price drop-must sell now!!!
Old Jul 12, 2008 | 03:04 PM
350zDCalb's Avatar
350zDCalb
builtZmotors
Exclamation sleeved block, stage IV heads-price drop-must sell now!!!
I have had these priced super low as is, but I need to move thee two items:
DARTON SLEEVED block with ARP 1/2" head studs...
$1900 shipped + NO CORE CHARGE
Stage IV Ferrea valve heads, port and polish...
$2900 shipped +NO CORE CHARGE
old price:
BuiltZMotors is clearing out some inventory. We have one of the stage IV cylinder head packages in stock. These normally sell for $3600 (+$600 core charge) without cams. We are offering these heads at a special price of $3000 shipped anywhere in the US (+$500 core charge) or $3500 without core.[/B] (core charge refunded when we receive your cylinder heads)
Stage IV Head Package-WITHOUT CAMS
redeck heads - to ensure mating surfaces between the block and the heads are exact
clean parts- prep before assembly- clean oil channels, outer surface, etc.
machine heads to accept ½” head studs- will still be compatible with standard 11mm studs as well)
Full Ferrea Valvetrain:
Ferrea 1mm Oversize Intake and Exhaust Valves
Ferrea Heavy Duty Single Valve Springs
Ferrea Titanium Retainers
Ferrea Valve Spring Locators
Ferrea Valve Locks
Ferrea Valve stem seals
Ferrea valve guides
3 angle valve job: 30, 45, 60 angles on valve seat, 45 angle on valves.
Headwork-Extensive port and polish, intake, exhaust, bowl.
head assembly- valves adjusted to cams- (valve lash)
TESTING: All heads are pressure tested AND vacuum tested to insure integrity in the heads and that the valves are sealed and machined perfectly before shipped out to customer.
Exhaust ports:
Intake ports:
1mm oversized Ferrea valves:
An additional service that we will now offer to further aid in the reduction of a long engine build wait time is our ready to go SLEEVED shortblocks that are machined for 1/2" head studs.
Whether you would like us to machine, blueprint, and assemble your sleeved shortblock (or longblock package) or if you simply want the sleeved block for your own engine build project, we will provide the most convenient (no wait!), economical option for your vq35.
These sleeves are installed by Darton themselves. They have been decked and have been machined with timesert inserts to accept a 1/2" ARP headstud. The bare block will come with 16 ARP 1/2" studs, washers, and nuts.
again... this is a bare block, machined with darton sleeves installed, machined for 1/2" head studs - use of steel insert timeserts (studs and hardware included)
NO WAIT!!! on the shelf!!!
-TODD
BuiltZMotors.com
505-480-1923
Old Jul 12, 2008 | 03:09 PM
Hraesvelg's Avatar
Hraesvelg
Got Uranium?
Jesus Christ that's cheap!
Old Jul 12, 2008 | 05:38 PM
Barzten1's Avatar
Barzten1
bump
Old Jul 13, 2008 | 08:41 AM
350zDCalb's Avatar
350zDCalb
builtZmotors
yep, i am need of money for a real estate deal gone horribly bad So, my loss is someone else's gain...
someone jump on this!!!!
Old Jul 13, 2008 | 08:44 AM
Hraesvelg's Avatar
Hraesvelg
Got Uranium?
This block and heads are not from an HR engine are they?
Old Jul 13, 2008 | 09:09 AM
350zDCalb's Avatar
350zDCalb
builtZmotors
no
Old Aug 2, 2008 | 11:03 PM
ATL_Red_G35's Avatar
ATL_Red_G35
PM me the BEST PRICE for both, shipped.
Also PM me the best price if you build that short block with CP Pistons, Pauter or BC Rods, JWT or BC Stage 2 Cams, Springs and Retainers, etc. assembled, balance, blueprint and shipped it.
Thanks.
Twenty4
Jan 17, 2016 01:20 PM
