Engine Intakes, Exhausts, Clutches, Turbos, etc...
Pre-Order your NEW HKS Turbo Timer!
Old Sep 10, 2008 | 09:58 AM
Andy@Performance's Avatar
Andy@Performance
Performance Nissan
Default Pre-Order your NEW HKS Turbo Timer!
PM me for pricing!
Official HKS USA Press Release
The All New HKS Turbo Timer
HKS USA, Inc., celebrating its 35th year as the premier manufacturer and supplier of automotive performance systems and parts, is proud to announce the ninth generation of the HKS Turbo Timer available for sale on September 10th, 2008.
In 1982 HKS introduced the world’s first Turbo Timer to assist in cooling down the turbocharger to prevent oil coking in the center bearing cartridge assembly. Oil "coking" occurs when a turbocharger is not properly cooled down and the oil that normally lubricates the center cartridge heats up and forms solidified oil deposits. A turbo timer allows an engine to idle for a preset amount of time after the ignition key has been turned to the off position and removed. By allowing a turbocharged engine to idle, oil continues to pass through the turbo until it has cooled down to the point where oil "coking" will not occur. Re-designed for 2008, the all new Turbo Timer Type-0 and Type-1 feature a new, slim low profile design with a separate LCD display and control unit following the same design concepts as the current HKS EVC and A/F Knock Amp.
The Turbo Timer Type-0 features a red LCD backlit display for easy visibility, 2 timer modes, and a battery voltage meter with a peak value indication and warning function.
The Turbo Timer Type-1 features a light blue LCD backlit display and has the same basic timing and voltage features as the Type-0 plus several monitoring and measurement functions. The Turbo Timer Type-1 features an Auto mode for the timer function allowing the Turbo Timer to automatically calculate optimum idling time according to the most recent driving pattern. Vehicle speed and RPM can be displayed on the Type-1's LCD monitor and a speed warning level can be set. A two-stage RPM warning can also be set and used as a shift indicator. When a warning level is reached the Type-1's LCD monitor will blink and an audible beep will sound. The HKS Turbo Timer Type-1 also features various measurement functions including 1/4 mile timer, 0-60 timer and a stopwatch function that can be used for lap timing. The Turbo-Timer Type-1 can read in either MPH/SAE or KPH/Metric.
The new HKS Turbo Timers are compatible with all HKS Turbo Timer harnesses to make for an easy installation.
Type-0
* Part # 41001-AK009
* MSRP: $99
* Positive Lit LCD
o Red Back Light
* Black Display Case (W:89.5mm/H:22.5mm/D:13mm)
* LCD Display (W:41.5mm/H:11mm)
* Black Control Unit Case (W:69.0mm/H:80.0mm/D:21.0mm)
* Timer Functions:
o Manual Mode (0-10 Minutes)
o Memory Mode #1 (1 touch, 1 Minute Setting)
o Memory Mode #2 (1 touch, 3 Minute Setting)
* Battery Voltage Display:
o Battery Voltage
o Peak Value Indication
o ON/OFF Warning Function
* Compatible with all HKS Turbo Timer Harnesses
Type-1
* Part # 41001-AK010
* MSRP: $155
* Positive Lit LCD
o Blue Back Light
* Timer Functions:
o Auto Mode (0-5 Minute Setting)
o Battery Voltage
* Vehicle Speed Indication Function:
o Vehicle Speed
o Peak Speed Hold Value
o Speed Warning Function
* Engine RPM Indication Function:
o Engine RPM
o Peak Engine RPM Hold Value
o Engine RPM Warning Function
* Display in either MPH/SAE or KPH/Metric
* Metric Distance Time Functions:
o Acceleration Distance (0-100m, 0-200m, 0-400m)
o Section Time (200-400m)
o Acceleration Time (0-100km/h, 100-150km/h)
o Auto or Manual Start for Quarter Mile Function
* SAE Distance Time Functions:
o Acceleration Distance (0-60 foot, 0-1/8 mile, 0-1/4 mile)
* Stopwatch Tool Time Measurement
o Total Elapsed Time
o Lap Times
Old Sep 10, 2008 | 05:41 PM
mikez97's Avatar
mikez97
could i have the type 1 with a harness the price PM'd to me.
Old Sep 11, 2008 | 09:29 AM
Andy@Performance
Performance Nissan
PM sent!
Old Sep 11, 2008 | 06:04 PM
COJ_General's Avatar
COJ_General
Type 1 with harness shipped to 33190? thanks
Old Sep 11, 2008 | 07:38 PM
specialized5223's Avatar
specialized5223
type 1 with harness to 79925
Thanks
Old Sep 11, 2008 | 07:41 PM
DracoLancet04Z's Avatar
DracoLancet04Z
type 1 and type 2 with harnesses shipped to 76203 please
Old Sep 11, 2008 | 10:55 PM
wenlipai's Avatar
wenlipai
how much shipped to El Salvador / San Salvador by usps express mail? i want the type 1
Old Sep 12, 2008 | 09:39 AM
Andy@Performance
Performance Nissan
There is no Type-2.
Andy@Performance
Performance Nissan
All PM's sent!
Old Sep 29, 2008 | 09:47 AM
Andy@Performance
Performance Nissan
Both Type-0 and Type-1 in stock NOW!
Old Oct 20, 2008 | 10:51 PM
wuomran2's Avatar
wuomran2
need type-1 with harness. How much it's shiped to 11413 and thank you.
Old Oct 20, 2008 | 10:57 PM
idrmofs7's Avatar
idrmofs7
both type 0 and 1 with harness shipped 85248 ty
Old Oct 21, 2008 | 09:43 AM
Andy@Performance
Performance Nissan
All PM's sent!
Old Nov 26, 2008 | 05:34 PM
Andy@Performance
Performance Nissan
BUMP!
Old Dec 5, 2008 | 10:15 AM
Andy@Performance
Performance Nissan
BUMP!
Old Dec 23, 2008 | 03:49 PM
Andy@Performance
Performance Nissan
BUMP!
Old Dec 24, 2008 | 12:31 PM
Total D's Avatar
Total D
evc 6 and type 1 shipped to 71430
Old Dec 24, 2008 | 12:55 PM
Andy@Performance
Performance Nissan
PM sent!
Old Jan 7, 2009 | 09:28 AM
Andy@Performance
Performance Nissan
BUMP!
Old Jan 22, 2009 | 08:37 AM
Andy@Performance
Performance Nissan
BUMP!
