*** STILLEN *** Exhaust, Intake, Pulley, Camber, Toe Arms, & Sway Bars ********
Vendor - Former Vendor
As one of the biggest Stillen distributor, we are proud to bring fine Stillen products to G37 owners.
1. Stillen 350Z Dual Exhaust System
Application : 03~08 350Z
ZR Single Wall Tips 504350 -------> PM for Price
Dual Wall Tips 504350D --------> PM for Price
STILLEN'S hot new exhaust for the 350Z is the result of months of development and testing. Made of 100% stainless steel, the system features dual pipes and mufflers and a lifetime warranty. It makes the most power of any 350Z system on the market and fits like a glove.
Retested on 9/11/03 in 5th gear dyno runs to add 16 HP at 5600 rpm and 14 Ft/Lbs at 4600 rpm. This is the first and best full cat back system available for the 350Z. The fit, finish, power and mellow tone have to be experienced to be fully appreciated. No other system available can compare
http://www.youtube.com/watch?v=GaH6kmUZkDM
2. Hi-Flow Intake Kit
Application : 03~06 350Z
Model No. 402833 -------> PM for Price
3. Camber Kit
Application : 03~07 350Z
03~06 G35 4DR
03~07 G35 2DR
Front Camber Adjuster 308035 ----> PM for Price
Rear Camber Adjuster 308365 ----> PM for Price
Rear Adjustable Toe Arms 308335 ----> PM for Price
Complete Rear Kit 308370 ----> PM for Price
4. Performance Lightweight PulleysApplication : 03~06 350Z
Underdrive Pulley Set + Belt Set 400336/400336B ----> PM for Price
Standard Pulley Set 400346 ----> PM for Price
STILLEN has long manufactured precision pulleys for our supercharger kits. We have used this expertise to produce a new line of high performance crank and accessory pulleys.
Each pulley is machined from 6061 aerospace grade billet aluminum with a bold new design to maximize performance, strength and minimum weight. 304 stainless steel sleeves are used for main seal contact points for durability. Stock timing marks are maintained and keyways are precision broached. All pulleys are CNC turned, milled and balanced based on computer generated designs.
Up to 80% lighter weight than stock steel and up to 10% lighter than other aftermarket pulleys, we've seen power gains of up to 10+ HP at the wheels.
5. Sway Bars.
Application : 03~07 350Z (except AWD)
Front & Rear set (5way adjustable) 304350 ----> PM for Price
Sway Bars maintain feel and control by balancing the vehicle and keeping your car from rolling excessively in the corners. They also play a critical function by keeping maximum tire contact with the road. Original equipment Sway Bars are often way too small for true performance. These bars are made from high strength aircraft grade steel. Such a strong material is required for maximum torsional strength and durability.
Some sway bar kits are adjustable, allowing drivers to adjust the ride from 7% to 70% stiffer than stock, making the vehicle pleasant on the boulevard and aggressive at the track
All STILLEN Sway Bars come complete with quality hardware and installation instructions (when applicable/necessary).
3. Camber Kit
03~06 G35 4DR
03~07 G35 2DR
5. Sway Bars.
