Engine Intakes, Exhausts, Clutches, Turbos, etc...
AEM Universal Stand Alone Engine Management System
Old May 4, 2009 | 09:17 AM
turbo_toys's Avatar
turbo_toys
Turbo Toys Inc.
Default AEM Universal Stand Alone Engine Management System
We have one AEM Universal Engine Management System(EMS) up for sale. This has been set up for the 350z.
AEM's Plug & Play Engine Management System (EMS) is the first of its kind and will forever change the way you look at fuel injection tuning! This user-programmable system plugs directly into a vehicle's factory ECU harness and requires no additional wiring. Windows™-based software (2000, NT, 98, 95, ME) makes the task of copying, viewing and manipulating data as simple as a click of the mouse. User-defined templates are easily configurable and enable tuners to establish "quick keys" to any pertinent information during the tuning process. The AEM EMS's infinitely-adjustable software allows tuners to program virtually any combination of engine control, power adders and auxiliary devices, and accurately deliver proper amounts of fuel and correct ignition timing for ANY boost level or operating condition.
Installs In Minutes
Since the EMS is designed to work with your specific car, it can be installed in minutes without the need to modify your vehicle in any way. You literally just unplug your factory ECU and replace it with the EMS.
Plug & Play Technology - No Wiring Necessary
Each EMS part number has been designed with a specific car in mind, meaning it will plug in exactly the same as the factory computer it replaces. It uses no adapter loom or external jumper harness. It has been built with the same plug that your factory ECU came with.
Fuel Table Automapping
With AEM's new Fuel Automapping software, you can tune your engine in literally minutes! All you need is an accurate air fuel ratio input and then let the ECU do the rest. You have the ability to define the target A/F ratio at 357 different Load/RPM points as well as all the accuracy criteria. Automapping is included with every AEM EMS sold at no additional cost!
Base Maps Included
AEM always make available base maps to help you get started. They are what you need to start your car, get a basic idle, make you're A/C work and more. AEM actually put hundreds of hours into their base maps on stock cars and even drive them back and forth to work in traffic as final tests. But what about heavily modded cars? Put a Big Turbo on your Si?, How about a ProCharger on your Mustang? Check out the AEM Electronics Forum because AEM makes available all sorts of maps for most of the common modifications. AEM probably already has a map for you!
Programmable Traction Control
Finally a way to put that power to the ground. With AEM's programmable traction control, you can get the 60 ft times you need. No individual wheelspeed sensors are required and you get to program the allowable acceleration rates based on RPM and Gear. This is included with every AEM EMS sold at no additional cost!
Onboard 512kb Datalogger
No more racing with your laptop in the passenger seat! With our 15 channel, high speed internal datalogger, you can finally get the data you need to take it to the next level. With access to over 400 internal operating parameters and featuring logging rates of up to 250 samples/sec per channel and "loop" logging, you'll practically be buried in data! Additionally, the logger can be activated based on a cockpit switch, RPM, car speed, load or throttle thresholds. The supplied AEMLog professional data analysis package supports math channels, multiple file & channel overlays and histograms. Of course, if you want to race with your laptop duct taped to your roll bar, go right ahead because we also feature adjustable speed PC datalogging. Both loggers are included with every AEM EMS sold at no additional cost!
10 Cyl Sequential Fuel Injection
The AEM EMS features 10 sequential fuel injector drivers. Any injector can be configured to fire in any order at any time. Also, any injector can be configured to run as a fully sequential Staged injector of any size. No shortcuts here, the staged injectors are fully sequential and you can define exactly how much fuel they deliver via a 357 point Load/RPM table.
16 General Purpose Outputs
Tired of trying to decide if the ECU should control your Radiator Fan or your Fuel Pump? Well, there's no way you could use all the outputs available on the AEM EMS. With 16 dedicated GPO's you can activate most anything. Both Low Side (switched ground) and Hi Side (Switched +12v) GPO's are available. Each is activated based on user defined Load, Temp, TPS, RPM and Speed thresholds. Alternately, they can be activated by dedicated functions like "Fuel Pump", Cooling Fan", "Gear Dependant Shift Light", AFR Warning light" and so on. Not enough for you? well every unused Fuel (10), Coil (5), Stepper (8) and PW (2) drivers are also available as additional GPO's bringing the potential number of GPO's to a staggering 41. Think about the possibilities.
7 Definable Switch Inputs
Want a 2 step launch control?, want to control your A/C?, want a dry nitrous setup? Want them all at the same time? Well then, what you need are switch inputs, lots of them. The AEM EMS has 7. That's more than anyone else. It's more than enough.
Electronic Boost Control
You don't need to buy a piggyback boost controller ever again! The one that is included with the EMS at no cost is state of the art. It can drive the factory or aftermarket boost solenoids and can work with all boost levels. It can run in open loop (MBC mode) or full feedback with a 357 point boost target table. Not enough? how about a cockpit boost target override switch or having the boost target defined by vehicle speed? The EMS can do it all.
Soft Cut Rev Limiters
Utilizing user programmable stages, the EMS offers 5 distinct modes of rev limiter. With ignition retard, programmable partial cylinder cut of fuel and/or spark and full cut of fuel and/or spark, the combinations are limitless.
2 Step Launch Control
The EMS gives you the ability to define a secondary rev-limiter, commonly called a 2-Step limiter (Full Throttle, Clutch In, you use both feet, 2 step, get it?). With a user defined RPM value and Cut %, you have the ability to tune your launch to suit the track conditions. Additionally, with AEM's definable switch inputs, you can use the 2-step without the requirement of wiring in a clutch switch.
Wet or Dry Nitrous Control
With the EMS, you have the ability to fully control your nitrous system, either wet or dry. The EMS features two 357 point fuel and spark maps exclusively for nitrous. This allows you to add any amount of fuel and retard the timing in any way you like. Add to this the ability to monitor your bottle pressure (with optional sensor) and activate your bottle heater and you have the ultimate nitrous computer. All this control is included with every AEM EMS sold at no additional cost!
Definable Knock Control
There's a reason why all new cars come with knock sensors and there is no reason not to use them. With the EMS, you can. User programmable knock thresholds and full control on the quantity of fuel to add and/or timing to retard, the EMS allows you unmatched ability to use these sensors to their full potential.
Full Idle Control
With support for both PW and Stepper Motor idle bypass hardware, the AEM gives you the flexibility to tune your idle just like the factory. It features adjustable feedback rate, programmable hi idle, timing and fuel trims based on idle speed and more.
4 EGT Inputs w/Fuel Control
The EMS lets you hook up 4 RTD type EGT sensors directly to the EMS. You can log the data or set up a fuel trim based on your exhaust temperature. This gives you the safety to run big boost numbers and only add fuel as you need it.
16/32 Hybrid High-Speed Processor
Utilizing an advanced 16/32 bit hybrid processor by Motorola guarantees the EMS will always be one step ahead even under the most demanding operating environments.
Wide Band O2 sensor Correction
Utilizing the input for the AEM wide band O2 sensor, you can set up a target air fuel ratio map based upon load and rpm and the EMS will auto correct to get you there. Of course you should tune the car first and get as close to your target as you can!!
Price: $2800 OBO Plus Shipping.
Please feel free to PM questions and Best Offer.
Thanks.
Old May 9, 2009 | 08:09 PM
turbo_toys's Avatar
turbo_toys
Turbo Toys Inc.
All PM's answered...
Old May 19, 2009 | 05:20 PM
DudeMan's Avatar
DudeMan
just curious what makes this universal aem unit worth $1000 more then some other places sell? i know that harness is not worth $1000
Old May 20, 2009 | 01:42 PM
turbo_toys's Avatar
turbo_toys
Turbo Toys Inc.
To answer your question here is the difference:
AEM’s Universal Programmable Engine Management System adapts to any race vehicle using the company’s flying lead wiring harness and sensors (sold separately). In addition to the features found in our Plug & Play EMS, AEM’s Universal EMS also includes 10 independent, built-in peak & hold injector driver channels, direct drive ignition and dual wideband UEGO controllers. Peak & Hold injector drivers enable users to utilize low impedance injectors with a true 4/1 Peak & Hold injector drive circuit. The Direct Drive ignition feature allows users to drive a coil directly from the ECU without the need for an igniter or ignition module, and a wideband UEGO controller is an essential tuning tool that provides a 0-5 signal for monitoring and tuning air/fuel ratios (AFR) on heavily modified high-performance engines.
Old May 20, 2009 | 03:06 PM
ZU L8R's Avatar
ZU L8R
Viper Sellout
The Viper guys love these casue it's one of the few that will control 10 injectors. You might try viperalley.com and there's always ebay which i know a lot of the guys watch.
Old May 20, 2009 | 04:21 PM
DudeMan's Avatar
DudeMan
i know what it is but that price is very steep
https://www.upscaleautomotive.com/p-...nt-system.aspx
and 350z harness
http://www.autoanything.com/performa...&from_search=1
thats thats about 700 cheaper then what youre selling them for
sales@czp
Sep 23, 2019 03:30 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
