Engine Intakes, Exhausts, Clutches, Turbos, etc...
haltech platinum for 350z!!!!
Old May 6, 2009 | 02:44 PM
Jtran Studios's Avatar
Jtran Studios
Vendor - Former Vendor
Default haltech platinum for 350z!!!!
Some Key Points for the 350z Platinum PnP Standalone Engine Management System:
· End User Tunable (not locked like some EMS on the market)
· Sequential Fuel and Ignition Control (32x32)
· Complete Intake and Exhaust Cam Control ('03-'05 Intake Cam control only) (24x24)
· Cylinder Trim Tables for each injector and ignition coil (8x8)
· Configurable AXIS and Load points for all tuning tables
· Tuning via MAF, TPS, or MAP
· Fuel tuning by Volumetric Efficiency (VE) or Injection Time (MS)
· Open/Closed Loop Boost Control, with wheel speed and wheel slip adjustments
· Dual Channel Closed Loop 02 Control
· Map Trace
· Onboard Data Logging
· USB Communication (no outdated Serial cable required)
· New Windows Tuning Software, ‘Haltech ECU Manager’
· 32Bit Microprocessor, 55MHz
· Plug and Play Loom
· User defined rev limiter ('03-'04 only)
· Auxiliary two-step rev limiter
· Knock Detection
· Overboost Protection
· User Configurable Inputs and Outputs
· Nitrous and Meth Injection Control
In your 350z Haltech Platinum Series PnP EMS package you will receive the following:
Haltech Platinum Series 350z EMS with onboard MAP sensor and onboard data logging
Plug and Play Harness
USB connection cable
Software and User Manual on CD
super duper deal!!!!pm for pricing and availability!!!!! retail $2299!!!
Johnny Tran
9365883735
Old Jul 18, 2009 | 07:35 AM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Amber/Johnny; PM Price w/ Dual Wideband & black bezel.
liqalu04
Jan 2, 2022 12:58 PM
issyz
Jul 2, 2017 03:04 PM
wanderingstuden
Jan 28, 2016 07:03 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
nanotech
Oct 2, 2015 05:02 AM
